Question about Toshiba Satellite A135-S4527 Notebook
My laptop not working Toshiba Satellite A135.
Okay, my grandma got me this Toshiba A135 Satellite brand new so I used it a little bit, then it started to freeze so I had to reset it. So after that I told my dad so we took it up and they said use the reset disc to reset the computer, now it doesn't work at all. My dad talked top a guy and he said it's the motherboard. Now it's out of it's warranty and I want to know what it coould be.
  • 4 more comments
  • Aron Jan 30, 2009
    Yes I get power and hear fans but it comes up black starts to boot and freezes. It doesn't work anymore...
  • Aron Jan 30, 2009
    It does not get past the boot system! THE RECOVERY FREEZES ON IT.
  • Anonymous Mar 11, 2009
    The Toshiba Satellite A135 often overheats ond hangs - I also have a dual cooler fan unit under it and it still crashes. I cannot recommend this PC.
  • laleyetunde Mar 11, 2009
    I formatted my laptop and could not find a Mass storage controller driver for my laptop.
  • ramesh singh
    ramesh singh May 11, 2010
    what exactly it is doing can u tell me pls,i mean is it turning on or not or what screen do u see clarify me pls in details.....
  • DEKR
    DEKR May 11, 2010
    do you mean recovery disk
    when you turn it on do you see any power lights and hear the fans
    Genius:
  • Toshiba Master
  • 1,102 Answers
WITH AC POWER
RUN YOUR WIN RECOVERY AGAIN.
YOU DON'T NEED TO COMPLETELY REMOVE THE BATTERY.
Posted on Jan 30, 2009
  • DEKR
    DEKR Jan 31, 2009
    CAN YOU GET INTO YOUR SETUP
    ON STARTUP then set to default settings press F10 to save and exit
    then restart using the ac power cord
    then restart
    Are you using the original cd that came with your system
    Novelist:
  • 126 Answers
Ok i got it as u said that u can hear the fan and it powers up but u cannot see anything on the screen iin that case what u can do is that disconnect the ac adaptor and then take the battery out of the computer and then without the power cord and the battery press and hold down the power buttoon for one minute and then connect the adaptor and the battery and the try and turn on the computer and then still if u do nnot see anything on the screen then turn on the computer and then connect the external monitor and if u see the display on external monitor then the lcd screen has gone bad and if u do not see the display oon the external monitor also then the video card of ur laptop has gone bad replace it ....good luck
or what u can try is that try lkgc (last known good configuration) and then try and boot the computer or try in safe mode....good luck
Toshiba pta 3xa 00w002 tecra ax3 sound driver install
Go to the Toshiba support site for your country (or the country where the laptop was sold). Select Mobile Computing, then Drivers Download.
You will be taken to a page where you select the laptop family (Satellite or Tecra, ...). Select the exact model. A list of available download is displayed. Use the filter at the top right to select All, or Win7 32 bits, or Win7 64 bits.
Here is a link to get you started.
Dec 31, 2011 | Toshiba Satellite A135-S2276 Notebook
Where can i buy a brand new motherboard for toshiba satellite A135-S2386?
There are several places that sell new boards and a few more selling used ones. Ebay has both and is the cheapest by a bit. Then there are laptop repair or parts places that only have new.
You can find which repair or parts store has your mainboard by simply searching for
laptop repair parts
That will get you a few thousand hits (and more) so you should be able to pick someone close to you or that has a good price or warrenty.
If you search for
toshiba satellite assembly instruction
you should find step by step instructions on how to get the board in and out with out resorting to hammers or explosives. Usually you may find those on the repair parts websites as well. If you have never done one before expect to spend a few hours. The hardest part is getting the top and bottom of the case apart. The rest is pretty straight forward to do.
Jun 15, 2010 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite A135-S2276 just suddenly stopped
first to do is check your charger... remove the battery then connect the charger.. if still not working.. you need to open the system check the dc connector if its okay.. now time to check the motherboard. maybe some chips bluwn or burn... shortage... this is always happens epecially those over heating the cpu fan is slow not enougth to give out the coold..
Sep 09, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba A135 Satellite not working.
i dought it is the motherboard. it sounds like you either have a bad hard drive or some bad RAM.
Jan 29, 2009 | Dell Latitude D600 Notebook
Laptop does not work anymore. (Toshiba A135 Satellite)
Do you get power?
If not, when you remove the battery do you get power?
If there is absolutely no power to the laptop (and you know the AC adapter is ok) then it's hardware failure. If its new enough, get it warrantied through whoever sold it to your grandma, or Toshiba.
Toshiba satellite a135-2326 usb not recognized
its a driver issue most likly down to vista (as always) have you tried the latest updates from the microsoft website yet?
Aug 11, 2008 | Toshiba Satellite A135-S2386 Notebook
Drivers for Toshiba Satellite A135-S4527
type this in your search engine ....
toshiba support-content list
some tittles of exactly what you typed in will display...
click on one and youll be at the download page...
just been there.I'd type the page in for u but its very long as youll see when u get there.
Apr 12, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
224 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
