Question about Toshiba 36A50 36" TV
How do i plug a game conlone to a direct tv box?
What do i plug the picture and sound cables and what channel do i go to?
    Scholar:
    New Friend:
  • 70 Answers
Skate,
are you reffering to a game console connecting direct to a TV screen?
1st try to check if your TV screen have a terminal jack indicating "A/V INPUT" A/V stands for Audio/video. if the screen doesn't have this, you'll be needing A/V to RF converter
2nd if your screen does have a terminal jack indicating A/V INPUT the next step you need to do is: check your game consul cable it should have a 3 RCA cable having RED/WHITE and yellow marking.
RED and WHITE cable marking stands for "AUDIO"
YELLOW cable marking stannds for "VIDEO"
connect this cable to A/V input of your screen following the color code ( yellow to yello/ red to red/ white to white) then from the screen press a button indicating "A/V" or "INPUT"
cheers,
mark
Posted on Jan 29, 2009
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Toshiba television/vcr combination
Also try changing the TV system's selector..
Mar 03, 2008 | Toshiba MV-13N3 Television
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
Viera TH-46PZ85U. gray box where picture should be
If it was a setting on the television, then the cable info would also be affected. Try a reset on your cable box, as the cable info is generated within the box from the data stream, whereas the picture is streamed from the provider.
If the reset doesn't work, it's time to call the cable company - it's not a fault with your telly.
Mar 05, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Feb 24, 2008 | JVC AV-27230 27" TV
New setup
do you get anything on screen, like the menu or channel number?
Feb 05, 2008 | RCA L42WD250 42 in. LCD HDTV
New, second hand Nintendo 64
claudia,
Not sure what you're actually connecting. First, if you have a switch unit, the antenna or your regular cable go into one side and the game in the other...it connects to the TV. If that's not what's going on...you've got to fix that up. Your local electronics store or Radio Shack can help with the right one. Most units use channels 2, 3 or 4 as set on the tv...not a cable box. There may be a small switch with some of those numbers located on the bottom of the unit so that you can switch to a channel not used for broadcast in your area.
Dec 07, 2007 | Nintendo 64 Console
Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Toshiba 36A50 36" TV Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
