Question about Jenn-Air JGS8750 Gas Kitchen Range
Jenn air range stove jsg8750 have a f1-7 error code
The control board was change and i still get a f1-7 error code. can u tell me where the sensors are located.
  • 1 more comment
  • krappemail Feb 05, 2009
    same problem, we get a code f1-7 and stove shuts off. Is there an eay fix.
  • Mark Egan May 11, 2010
    Are you getting an F1 and F7 codes?
  • clarkco2002 May 11, 2010
    did u replace the touch pad?
  • 412 Answers
Hi there...
Error F1-7 means --
Replace touch pad or clock assembly (also called the ERC).
Good Luck!!
Posted on Mar 20, 2009
  • tomj66 Aug 26, 2011
    Had same problem with mine. Repair company charged 373.80 for new? part and 262 labor.
    Noticed wiring harness to touch pad had a price sticker for 75. Basically what they did was peel off an defective touch pad and replaced with new one and charged 373 for not a new part.
    So buy new touch pad for 75 and replace yourself as an option.
Error code 000f
Use a multi-meter to check the ohm's resistance of your temperature probe: should be 1100 ohms at room temperature = 72 degrees F. Range Stove Oven Temperature Sensor 12001655 Multimeter DM10T
After time, the connections between the temp. probe and the control board usually benefit from being disconnected and re-connected to keep corrosion from interfering with the resistance redings the control "sees" from the probe...
Jul 11, 2016 | Jenn-Air Ovens
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
Re: Jenn Air #svd48600b Gas Stove Top works... Oven and Broiler not working(Elec.) I replaced Electronic oven control assy...It works correctly, but never gets Hot!! Any ideas??
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Aug 24, 2009 | Jenn-Air Kitchen Ranges
Jenn air range model SCE30600B error code FC blinks with beeping noise. After resetting the temp down to 350 to keep from burning a pizza error code FC started blinking along with continual beeping. I have...
replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
Feb 03, 2009 | Jenn-Air SCE30600 Slide-In Electric...
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Failure
Code
JENN-AIR
Failure
Code
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air JGS8750 Gas Kitchen Range Logo
1,239 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
