Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Main power light turns on but i have no picture or sound
I have a 50" Pioneer TV model sd-p50a5-k. When i turn the power on the red light on the front panel turns on and i hear a click in the back of the TV. I took off the back panel and i can see a red LED that is lit up, but i don't get picture or sound. I tried using a voltage tester to test the power supply board (part number AWV1622) and I tried to find a bad fuse or maybe bad saudering, all the fuses seem fine and so far no bad saudering. I did find that everything on the "primary power" part of the power supply board is getting power and appears to be woking fine. Nothing on the "secondary power" part of the board is getting any power at all. I am not sure what supplies the power to the secondary or if there is a part that cannects the primary to the secondary that could be faulty. Any help that can be offered would be greatly appreciated.
  • kmac4 Feb 04, 2009
    I have the same exact issue. When the tv is tunred on you hear a click like it wants to power up, but then goes straight to standby mode.
Take a closer look at the power board fuses. There is a fuse numbered 106 a little ways away from the rest of them. I have this same model and got it working long enough to diagnose a bad flyback transformer by replacing this fuse with one from Radio Shack. At some times, I could put in a new fuse and have the set work for a few weeks. The flyback transformer is available from parts.pioneerelectronics.com for around $60.
Posted on Mar 20, 2009
I turn my TV off everything was ok..then I turned it back on but no picture sound only ,,,why ?
you might try do a hard reset. turn tv off unplug it hold power button on tv for bout 30 sec. then plug it back in. i had a similar problem and this worked for me.
Oct 08, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50 inI
Hi, I am just curious. What is going on wih the Television? Thanks, Mike
Nov 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
50" Projection TV
your set was going into protective shutdown. Probaly a leaky diode that was raising voltage that triggered the shutdown circuitry.Toshiba has good service info available to trubleshoot the power supply and shutdown circuitry. let me know if you would like me to post a link on where you can get this troubleshooter manual .
Feb 24, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
50 projectin tv
what model do you have?
Jan 13, 2008 | Televison & Video
Pioneer SD-P40
Check to see if Q118 is shorted on video/defl pc
Aug 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
380 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
