Question about Canon Pixma MP800 All-In-One InkJet Printer
"ink cannot be correctly detected" error U130
I just changed all the ink cartridges in my printer and an error keeps appearing on the cyan cartridge. The error states "the remaining level of the following ink cannot be correctly detected".....error U130 Can anyone tell me something to do?? Im really sick of paying for more ink cartridges when there is nothing wrong with the ones ive bought, Ive already changed it twice and it keeps giving me the same error.
  • 1 more comment
  • Anonymous May 02, 2008
    ON my Canon MP500 I got around the message 'U130 the remaining level of the following ink can not be correctly detected' by holding reset for > 5 sec, so it disengaged the ink level detection.
    Now, how do you re-engage the ink level detection?
  • Anonymous Feb 08, 2009
    Same thing; after replacing the cartridge A, cartridges B & D are showing this error!
  • Joe Cos
    Joe Cos Nov 10, 2017
    Worked on my Canon Pixma MX892
Hold down the "Stop/Reset" button for 5 seconds and it dismissed the first message, but then there was another for a different cartridge, etc. Eventually I got it to work.
Posted on Sep 25, 2007
  • LilTunnie Jul 26, 2011
    brilliant thank you for saving me --lol
  • Meagan Hughes
    Meagan Hughes Mar 23, 2016
    Thank you so much! I kept pressing the stop button but never thought to hold it down a few seconds...
  • Canon Master
  • 705 Answers
If you have changed the cartridge twice and the error remains, it would suggest the cartridge is not at fault. Look at the contact where the cartridge inserts into the carriage and make sure they are A) Clean and B) Not bent or distorted If you are certain the contact between cartridge and carriage is good then it would suggest there may a fault further down the line. This would implicate either the cable running back to the main board or the main board itself. It would be worth spending a little time to fully investigate the carriage to cartridge contact. Let us know how the progress goes.
Posted on Jul 26, 2007
I had the error message U071 and U130. I pressed the stop/reset, OK, the black and color start buttons all at once and the error message just disappeared.
Posted on May 17, 2008
  • 3 more comments
  • genevis Dec 01, 2010
    YES IT WORKED. THANKS. GENE
  • love_is_carl
    love_is_carl Feb 23, 2012
    OMG IT WORKED!! i wish I would hhave seen this a yr ago! do u know how many inks I have bought since then while i had ink stored!! thank u so much i thought it was just me not doing it right!!! yeyyyy
  • Maqsood Ahmad May 22, 2013
    Thanks..... you save my lot of time & offcourse mony this worked for me time being
  • David Jun 04, 2013
    Thanks so much! I had the same error message w a yellow cartridge. It was not giving the error when I would put back in the old depleted one, so I knew there was nothing fundamentally wrong w the printer.
  • Untan
    Untan Nov 10, 2018
    It working! thanks
    New Friend:
In my case i just used cancell/stop button & it worked for my canon pixma MG 5150 .Thumbs up
Posted on May 22, 2013
I put a refurbished cyane ink cartrage in and I get error. It says it cannot read the ink cartrage take out and put back in. I do that and it still will no work.
your printer cant "read" cartridge E-label
you have to replace it or replace cyane cartridge whit new one
Good Luck!
Jun 27, 2010 | HP LaserJet 4700 Printer
U130 ink message on pixma mp620
Very simple solution: When the pixma mp620 screen shows error U130, Hold down the stop (red triangle) key for about 7 - 10 seconds. This overrides/turns off the ink monitoring function. The printer will begin "thinking" for a bit and then start printing. Note: you may have to do this seperately for each color. You'll also notice that when the lid is open and the cartridges are in position for changing, the cartridges that used to be "out" are no longer flashing red, nor a stead red. They are dark.
Feb 17, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
My printer is canon IP 1900 Series. my canon problem is error messege display ''the following ink may run out.balck.. the function for detecting the remaining ink level will be disabled since the ink level...
It would appear that the black ink cartridge is either out of ink or running out soon.Change the cartridge.If your need to print now and don't have a new cartridge try this open the unit pull out the black cartridge shake it and the reinstall it you may get a little more out of it.If this is a new printer the cartridges install are always limited in use,so you'll buy more.If you must print know try changing your font color to dark blue avoiding black.Good luck.
Sep 05, 2009 | Office Equipment & Supplies
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
I have a hp 7580 printer. Recently changed ink cartridges, almost immediately afterwards, i received an error code stating the printhead needed replacing. I changed the printhead as directed, rebooted to...
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
Need help U130
Just press the "Stop/Reset" button for about 10 seconds and the cartridge will be accepted. Do so for every cartridge sequentially. Good luck
Aug 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
ERROR U130
The remaining ink level cannot be correctly detected. Replace the ink tank and close the Scanning Unit (Printer Cover). Printing with an ink tank that was once empty may damage the machine. If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the Stop/Reset button for at least 5 seconds, and then release it. * With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any machine malfunction or damage caused by refilled ink tanks. See “Replacing an Ink Tank” on page 46.
Apr 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
21,891 people viewed this question
Clive
Clive
old marine
old marine
