Question about Roper REX4634KQ Electric Dryer
I need to know how wires on the power cord connect
I need know does the red wire go with black wire or black wire go withgreen or white
    Scholar:
  • 140 Answers
Red on the left.
White in the middle.
Black on the right.
Green on the case/chassis ground or green screw with the small dashes on it.
If you don't have a white wire but the the green in the middle position.
White/red = far left
Green = middle
Black = right
Posted on Jan 29, 2009
Bought a whirlpool dryer used and the power cord isnt connected how do i know how to connect it
Hello
Here ya gooldtech2332.jpgoldtech2332_0.jpg 3 wire cord center to center outside to outside 4 wire red to red white to white black to black and green onto the cabinet
Aug 13, 2011 | Whirlpool Dryers
On the top of the dryer there is block where the power cord attaches and there are 6 spaded treminals wit the following wires attached from left to right they are black wire, 2 blank, whiye double wire,...
the green wire is the ground wire,there should be a screw or connector for it near the block,it just connects to the frame so the unit is grounded,you should see on the cord a white,black,red and a green ground wire,on the block you should see the white wire connected,the black on another screw and the last one is for the red,if the white is in the middle the black should be on one side and the red on the other,they are color soated,if you say there are red small wires the large red should connect with them just like the black does,as long as you keep the white wires together,the black wires together and the red wires together you'll be fine and ground the green wire to the frame
Feb 22, 2011 | Dryers
If you are installing a new power cord on a whirlpool dryer and you have a power cord with one green wire one black wire one white wire and one red wire where do you connect the wires when the terminals on...
Good day,
The green is screwed to any convenient place on the cabinet. It's a safety ground wire.
The white goes in the middle of the block. The red and black go on either end. Doesn't matter which.
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
The power cord on my Whirlpool washing machine is not connected. There are 4 cables (red, black, white, and green). I can see where the black, white, and red, but where does the green one go? There is...
The following link explains how to correctly install a power cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
The main difference between the 3-wire and 4-wire configuration is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wire are terminated on the terminal block in the back of the dryer:
- In a 4-wire configuration, these two wires are INDEPENDENT of each other and are terminated separately.
Terminate the wires at the terminal block by matching the corresponding colors:
RED to RED (HOT) 120VAC
BLACK to BLACK (HOT) 120VAC
WHITE to WHITE (Neutral) 0VAC
GREEN (Ground) - attached to a ground lug that grounds it to the equipment cabinet.
If you have any questions, please let me know. I hope this helps you
Dec 24, 2009 | Washing Machines
Dryer did not come with electrical cord so I bought one.
The main difference between the 3-wire and 4-wire configuraiton is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wire are terminated on the terminal block in the back of the dryer:
- In a 3-wire configuration, these two wires are connected together via a ground strap at the terminal block.
WHITE to WHITE (Neutral) 0VAC - Neutral should also have a ground strap attached that grounds it to the equipment cabinet or ground lug.
NOTE: Newer homes built after the year 2000 REQUIRE a 4-wire configuration to be in complaince with the National Electric Code. In addition, some newer appliances may not work correctly without a 4-wire power cord.
Dec 23, 2009 | Kenmore 62602 Electric Dryer
Replace a 3 wire power cord with a 4 wire power cord.
red on one end, black on the other, white in the middle, green to cabinet ground.
Jun 12, 2009 | Dryers
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
Putting new power cord on dryer i have a 3 cord set up a red wire a black wire and a white wire and dont know which wire to connect to which.
on the back of your dryer.
1.connect the white wire to the center of the junction box.
2.than take the red wire and connect it to the left side of your junction box.
3.than take the black wire and connect it to the right side of the junction box.
If you have a green wire on the cord as well. PLEASE make sure it is connected to the dryers back panel. do not leave it to hang.
Please do not forget to rate and comment about your experience today.
Aug 16, 2008 | Whirlpool Dryers
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
71 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
