Question about Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145-2
Washer not wrorking, filter full of water, water not coming iunto machine, water is coming into the pipes from the mains but is not releasing into machione. when a program is selected it makes a clicking sound and moves a little bit around the dial and does nothing. when set to drain i ti makes sounds like it is draining but must not be completely as the flitler is full of water
  • 183 Answers
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Posted on Jul 30, 2007
SOURCE:
How do i open the filter cover for my whirlpool awm 5145/3 washing machine?
Tip is back a hair and remove the screws and bottom panel then grab the cap045bec0.jpg7d5c207.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 13, 2010 | Whirlpool Washing Machines
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
I have whirlpool awm 5145 the counter turnsbut nothing happens
Check the lid switch. There should be a small pin on the lid that will push the lid switch down when it is closed. There are two wires going to the lid switch, jump these two wires together and if it works then replace the switch.
Unplug the washer before doing any work.
Dec 16, 2008 | Whirlpool Washing Machines
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
Awm 5145
Possible your hoses into the dispenser box hv a problem; plug off wall. Open the top of the machine to examine the hoses.....
Jun 24, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
353 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
