Question about Linksys Wireless-G Broadband Router
Password block I am trying to get to the config page and when I type in the default gateway of 192.168.1.1, I get stalled on the password page. I've tried using username admin and both password and admin as the password. Is there anyway to bypass the password prompt so I can get to the config page?
    Scholar:
  • 80 Answers
If you dont know the password than last option is to reset the unit to company default and than you can login with admin and password admin. To reset it to company default there is reset button behind it so press it by pen point for 5 to 10 secs. So this my resolve your problem
Posted on Jan 29, 2009
I need to find security key or passphrase for my linksys wrt54g
If it's a new router OR If you forgot the password you can follow the given solution. If you've also forgotten the default username and password then on the back of the router you will find a pinhole for resetting. Disconnect all cables from the router except the power. Put a pin in the hole and hold it there till all lights goes off and comes back on again. Then follow the steps mentioned below.
Click on Start - Click on Run
Type "CMD" - Click on OK
Type IPConfig and hit Enter on the black CMD screen
You will get the IP address and default gateway. Write down the default gateway and close the CMD window.
Goto Internet Explorer or the browser you are using. Enter the default gateway on the address bar and press enter. You will get a window to type user name and password. You can use the default username and password as given below if you have not changed it.
Default username = admin
Default password = admin
Click on the wireless tab as highlighted in the image below
Click on wireless security as highlighted below
Click on the drop down of security mode (1) and select WPA or your desireable security then type the passphrase in the box (2) and click on save changes.
Disconnect the ethernet cable and try to go wireless and put the passphrase you typed on the router page.
Regards,
Shrey
May 30, 2011 | Linksys Wireless-G WRT54G Router
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
Hello, Trying to get into the Config Software
Try the other common ones: 192.168.1.1, 192.168.100.1, 192.168.0.1, 192.168.10.1.
If those doesn't work, open a command prompt, and then type in ipconfig /all. Look for the value in the Default Gateway, and use that.
Apr 06, 2011 | Computers & Internet
I'm trying to get into my router config settings
From your computer, go to start, the run, then put in cmd and press ok. This will get you to a black screen.
Put in the following and press enter:
ipconfig /all
Look for the gateway ip address. This is your router ip address. That should get you to the router from your url in a browser.
If this solves your problem, please leave feedback.
Feb 21, 2010 | Computers & Internet
I am trying to secure my router with password but
would you mind providing make and model of router? You can connect to the router with ethernet cable and look at your Gateway IP address. Take that ip address and type into your browser as http://XX.XX.XX.XX Where the XX's are your gateway ip address. this will get you to your routers config page. From there you can try the default password for the router then go on the actually configuration. But its hard to direct further without know specific make and model.
Sep 22, 2009 | Belkin Computers & Internet
Cannot login to wbr-2310 router's config page
Disable firewall on your computer. It seems that it's blocking you from getting in the setup page. you may also try using another computer to login just to isolate your problem
Jun 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Zyxel Prestige660HW-T1_cannot log-in to config page
have you tried admin/password or admin/admin
Mar 18, 2009 | Zyxel P660HW-D1 Router
How can I secure my zyxel Router P-330W at home?
hi...
you need to go to the computer which is connected wired to the zyxel box,in the computer click on start,run,type in cmd,and hit enter,on that black box type in ipconfig,hit enter,you wil get a list of result check default gateway(eg of default gateway is 192.168.0.1)go to internet explorer page,in the address box type in the default gateway without http or www,it will open the zyxel page for you,it might prompt you to put in the user name and the password,if it does then donot put anythingin the name of username and put 1234 as password,in this page you will see an option that says wireless,click on wireless and then click on advanced,under you will see the wireless security option where you can go ahead and make you wireless connection secured.
http://us.zyxel.com/upload/download_library/P330W_UG_V_1%201(5).pdf..this is a link for user guide u can download this to udnerstand other features that there in you router..
vedhick
Feb 26, 2009 | Zyxel P660HW-D1 Router
Password not working
There is no way to bypass this... all you can do is reset the router.
On the back you will find a hole with a reset button inside. You have to press it with a writing pen.
Press the button with the pen while unpluging and reattaching the power cable to the router. Continue holding down the reset button for 10-15 seconds after the power is re-applied.
Then you should be able to access the router by 192.168.1.1 and using the user = admin and password = admin.
Jan 29, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
