Question about Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive
Problem pen drive
My pen drive was covered under lifetime warranty. For 4 months it worked fine. But after that it failed to work properly. In the properties it was showing 0 bytes usIt was covered under lifetime warranty.
  • Anonymous Feb 22, 2009
    after isert pen drive there is no notificatin in my computer
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
  • 24 Answers
Ya its lifetime warrenty and they provide you warrenty and you can recover this error by doing this:
go to transcend website and download this software;
(http://www.transcendusa.com/products/online_recovery.asp) and then you have to select repair and save data..
and then also if you dont get ur full data,you can download Pen drive recovery from many sites(search on google) and recover or else email me at devgolani@gmail.com for full software..
Regards
Devesh Golani
devgolani@gmail.com
Posted on Aug 29, 2009
Which is best pen drive
this will vary on a persons particular choice these days all usb drivers perform vey well
this will vary depending on the brand capacity of the pen drive
also buy one with a lifetime warranty
transcend are good and have lifetime warranty
another good brand is kingston 5 yr warrnty
adata another with life time warranty
corsair voyager 10 year warranty
if you need more with this or you are having problems with your scan disk drive post a reply
http://www.brighthub.com/guides/usb-flash-drive.aspx
complete guide to usb drives
hope it helps
May 07, 2012 | SanDisk Computers & Internet
I have bought a Kingston 16 GB USB Pen Drive, But when I Plugged in the Pen Drive it doesn't worked at all. Please Help me...
Seems like there is either a problem with the USB stick, or with your USB port. Do other USB devices work properly? If so, you might want to return that USB stick now it's still under warranty.
Mar 13, 2011 | Computers & Internet
Hi i purchased a transcend pen drive one month back but i unpacked it 2 weeks ago only and i used it hardly 4 to 5 times and now its not working.its a 4gb pendrive
try it on different computers. If it doesn't work in any of them, you can exert your right of warranty and have it fixed (unless you bought it already used, in that case you need to ask to whoever sold it to you).
Hope it helped,
Franz
Mar 01, 2011 | Pen Drive V-Stick 4GB MP3 Player
Just bought new pump. My old one lasted for 12 years. New one is 4 months old and recently started to make a loud whine or screeching noise when operating. It works fine but is very loud. I have trouble...
Most likely the bearings on the motor are going out. 4 months is way too soon, but it is possible you got a lemon. Unfortunately I wouldn't expect the new one to last 12 years. It's possible but unlikely. You should however get at least a few years. If the shaft seal on the motor shaft between the impeller and seal plate failed then water can drip back along shaft and get into motor bearings. This will cause motor bearings to fail. Even if this is not the case the motor bearings can fail even though it is rare to do so within first year. I would contact the place you bought the pump from, or whoever installed it. It should have at least a one year warranty. If for whatever reason this motor is not covered under warranty and you have to replace it, I would consider rebuilding it. Normally I don't care for rebuilds, but if the motor is truly only 4 months old then rebuilding it would be a good option.
Sep 23, 2010 | Polaris Pb4 - 60 Booster Pump
Cruzer isn't working after a while
Hi
Thank you for your query
If you have tried it in multiple machines then unfortunatley the pen driver has burnt out. This is not to uncommon, Sandisk pen drives do come with a 5 year or a lifetime warranty, so please contact them for a replacement/refund
I hope this has been useful
Feb 28, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I hve purchased panasonic split a.c. b4 1 month only, mi remote senson is not working properly, i mean when i push mi remote button, its effect does not come in mi indoor unit sensor.
Ok, there are a few things to check.
1. Batteries on the remote.
2. Reset remote - switch sometimes in battery compartment and sometimes behind cover, need to press with sharp nib or pen.
3. Check on indoor unit that remote has been selected on the manual/auto switch, located under the cover on right hand side.
4. Remove indoor unit cover complete, (three screws behind the louvers and one on the electrical cover). Change the remote sensor board.
Mar 10, 2009 | Panasonic Heating & Cooling
Pen drive is not opening
have a 2gb transcend pen drive.till now it was working properly but now wen i try it says insert an drive into I.the light is glowing and it is getting detected.But i am not able to read the data.anyone can please help me.
Aug 11, 2008 | Transcend (589307) Media
HC 1500 skewed image issue
Hi there
I've worked on a few Mitsubishi's in my lifetime and one of their most common problems is the DMD Board that goes faulty and this makes the image go all pear shaped.
If you've only had the unit for 3 months now it should still be under warranty and the warranty covers these kind of repairs.
Hope this helps you !
Mar 26, 2008 | Mitsubishi HC100U Multimedia Projector
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive Logo
208 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
John Porter
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
