Question about Philips MRV700VR DVD Recorder/VCR
Philips DVP620R This DVPR willnot play back images recorded on digital chanels but will play back recordings of terrestial channels. I have ensured that all scart connections are good and allincoming aerial connectios are good. Recordings are ok from all of the terrestial channels. 1)I have reset the Digital terrestial receiver to the manufacturers origional settings and previously this action has worked, but on this occasion has not corrected the fault.This unit is about 21/2 years old.
3 Suggested Answers
SOURCE:
  • 6771 Answers
SOURCE: CANNOT TUNE TV CHANNELS FROM
You need to purchase a digital converter box in order to receive the proper signal, the only exception would be if your antenna is digital ready. I would suggest talking to a tv tech to find out if you need additional changes.
Posted on Dec 29, 2010
  • 1114 Answers
SOURCE: Phillips DVD recorder connection issue?
SCART is designed to carry analogue standard definition content. So if the input signal is high def. it will distort.
Posted on Jun 12, 2014
CANNOT TUNE TV CHANNELS FROM TERRESTIAL AERIAL INTO NEW SAMSUNG RECORDER
Dec 29, 2010 | Philips DVDR70 DVD Recorder
Have a new digital TV, can only record the 5 terrestial channels, how do I tune in to the other digital channels, i.e. BBC3, E4 etc.
It's not clear what you mean! So one of these answer might solve it. If you are talking VCR recording it must either have a freeview tuner or have a freeview box connected to it via a scart. Otherwise it will only record the five terrestial.
Digital TV -you must have a good aerial otherwise you will not pick up all the stations. If it has a hard disc drive the same will apply.
If the terrestial stations have any grain or the picture is not as clear as a bell on all, then your aerial will not be good enough. The type of aerial should be for freeview. See image below also you need to have CT100 cable (the stuff used for satellite) not the old brown co-axial cable (see below).
Jun 05, 2010 | Televison & Video
Are there problems recording to a vcr when using a digital converter box?
Not at all, as long as the channel selector on the back of the VCR is set to channel 3 to receive the signal and record. Connect the digital convertor box to the VCR. Connect a second co-ax cable to the TV to complete the signal loop. Tune your TV on the channel you want to watch/record. Put the VCR on channel three on the display screen. Try recording and play it back. This will ensure all your connections are correct. Hope this helps, if not let me know.
Oct 27, 2009 | Zenith VR4207HF VHS VCR
Sanyo DVR-V100E DVD recorder +VCR - will this model record any terrestial digital channels?
It does NOT have a built in freeview tuner. You would have to connect a Freeview box to one of the scart sockets and set it to record from the AV channel the box is connected to.
Oct 06, 2009 | Sanyo Televison & Video
I can't record normal tv progrma from HD tv
My dear friend where you connect the antenna source to the dvd or to the vcr or tv because ,if you wanna record anything you need to connect the antenna source to the dvd and put the channel you wanna record on him
Jul 25, 2009 | Televison & Video
Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Oct 18, 2008 | Boss Micro BR Digital Recorder
Record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Oct 12, 2008 | Televison & Video
Fault
as long as you have a good digital aerial connected to the recorder and you are in a good signal area then the channels should have been found automaticaly and stored on the machine.. a manual search and store would also work ok.. check your aerial connection/aerial type and any info you can find on freeview availabiliy in your area.. do you or anyone in your area have any other freeview device running ok?
Jul 28, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Philips MRV700VR DVD Recorder/VCR Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
