Question about Maytag MMV5000 Microwave Oven
Loud noise, stopped, then ODOR! Toxic? NOT a Maytag, sorry!
Not sure what make it is, but it's 6+ yrs old.
  • ourhome111 Jan 29, 2009
    Very helpful, thanks very much! Will show this to my husband, who is handy, but will probably replace it.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, there are only a couple of components that could produce a loud noise from the inside of a microwave oven:
  • fan blades breaking (if one is present);
  • carousel/turntable motor;
  • a capacitor in the power supply section of the main board (most likely).
All of the above are reasonable repairable if you are considering a DIY (do-it-yourself). The greatest challenge is determining which and familiarity with the use of a DV/VOM.
The odor could be the component that produced the sound burning. As stated above, most likely a capacitor. Should this be the case, it would be bulging on top and would have spilled its die-electric materials around (brown paper), you can try component level repair (just replace with same specs) or replace the entire board.
With all said and if you would factor in cost of repair (especially if you are seeking the services of a qualified professional), downtime and the efforts to effect a repair, you may want to re-evaluate your options and considerf a replacement.
Good luck and Thank you for using FixYa.
Posted on Jan 29, 2009
Carousel model.about 20yrs old.Humming noise really loud,then it stopped with no power and would not restart.It had not been used for approx 10 yrs until now.
Main fuse may have blown due to a possible failure in the high voltage doubler circuit. Check high voltage rectifier to see if it is shorted. Discharge high voltage capacitor first so you don't electrocute yourself.
May 02, 2016 | Sharp Microwave Ovens
Have a 10yr old ge microwave--was heating up food when it started making a loud bzz noise and then burnt plastic smell came from outside of the microwave and it didn't heat up food. It was working fine...
Yes it is definitely the magnetron and yes you could change it your self if you are good with electronics and tools (considering that the MAGNETRON DRIVER CIRCUIT is OK) but it is normally cheaper to buy a new microwave oven
Sorry!
Jan 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
It is making a humming noise but not heating.
sounds like a crack in the magnetron
a bad transformer
or a bad rectifier
sorry i cant be more help
Oct 10, 2009 | Maytag MMV5100A Microwave Oven
Noise & vibration
Sounds like Magnetron MAY have shorted or an HV rectifier shorted.
Also there is a resonating cap for the current limiting trnansformer typically. That may have shorted.
Repair shop is in order.
Oct 07, 2009 | Kenmore 60659 Microwave Oven
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Sep 15, 2009 | Microwave Ovens
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
Microwave makes loud noise and does not heat. Smell of light burning
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | Whirlpool GH8155XJ Microwave Oven
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
Maytag MMV5000 Microwave Oven Logo
160 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
