Question about Panasonic DMP-BD30K Blu-Ray Player
Panasonic DMP-BD30 won't read blu-ray disks
This unit is one year old, was stored in a closet for 11 months after being used one month (divorce situation). Worked beautifully for that month. Plugged it in to the same video setup I had before in my new apartment, and now refuses to play any blu-ray disk (says "NoREAD", then "STOP"). It does play regular DVDs...what a waste.
I'm guessing from the way its acting that it's out of warranty. Really angers me that for so little use I've got to pay someone to fix what is obviously Panasonic's problem. Any suggestions? Anything I can do other than drop a couple hundred bucks fixing or replacing this boat anchor?
  • 6 more comments
  • scottdeaver Feb 02, 2009
    Cleaning the disk was the first thing I had tried. The second thing I tried was upgrading the firmware to 2.6 (which couldn't be done via the instructions on the Panasonic website - I had to use the SD card and get the instructions from a Best Buy salesman, believe it or not). Even with the new firmware, still wouldn't read blue-ray disks. I bought a Sony at Best Buy (which I should have done in the first place) and that one works works fine. I'll send this boat anchor off to Elgin, Illinois, and they will try to charge me some outrageous amount. When I decide it isn't worth it, they will then try to charge me $65 to send it back to me (the actual cost is around $11 UPS) in hopes that I will let them keep it. When I refuse to pay the exorbitant charge, they'll keep the player, fix a $2 resistor that they know goes bad in these when you build up static electricity walking across the carpet in the winter because their ground plane is insufficient, and resell it as refurbished for $200.00. That's how Panasonic operates (a friend of mine works for one of their contract shops). I learned my lesson, will buy Sony here on out.
  • Anonymous Mar 16, 2009
    Plays only regular DVD's after fifteen months of flawless playing. Odd....
    Put in the newer firmware 2.7 dice. Paid a whopping 499.00 for this thing. Feel sick about it.
  • scottdeaver Mar 26, 2009
    I sent the unit off to the Panasonic repair facility in Elgin, Illinois. They determined the drive was bad (cost to repair $350.00), and even though the purchase date was marginal for the one-year warranty, they replaced the drive under warranty and sent it back to me free-of-charge (I did have to pay the $20.00 to ship it to them in the first place). Because they chose to be generous about the warranty period, my comments about them over-estimating and then keeping the unit were wrong and not fair to them. The unit works great now, and I will keep in mind the suggestions about keeping the laser clean (although I should note the technician did state that they've had to repalce a "ton" of these drives). Thanks for the help.
    You will need to get an RMA# - the live chat option on their support site works best and is the fastest. Alternatively you can call the tech support hotline number or the service center directly (see below). I've also posted the address. I also did not have my receipt - I knew the date I bought it from a Best Buy cancelled check. I wrote them a letter explaining the problem, and gave them the honest date even though it was a few days over the warranty limit. They called me and asked me again when I bought it, and then cut me some slack on the exact date. I don't know if they would do that when the difference is as great as three months, though, but probably no harm in asking (they will know if you lie becasue of the unit serial number - they can't know exaclty when it was sold, of course, but they do know when it was manufactured and the gerneral time frame they were sold from lot numbers are coming in for service sold by the same vendor. Despite my first comments about an earlier experience with my Panasonic projector, in this case they bent over backward to help me out, so hopefully they will work with you.
    NTSC Technical Support Hotline
    Phone: 1-800-528-6747 (option 2)
    Fax: 1-888-809-6198
    9am - 9pm EST M-F
    Or via the Internet
    Repair Center
    Panasonic Repair Center/HSI
    1615 Dundee Avenue, Dock G
    Elgin, IL 60120
    Phone: 1-800-528-6747 (option 1)
    Fax: 1-800-446-8634
    8:30am - 6pm EST M-F
  • Anonymous Apr 11, 2009
    Exact same problem for the most part. Won't play brand new blu-rays. Still plays older ones, DVDs, CDs, and MP3s on DVD-Rs. I'm updating to 2.8 firmware now. I'm hoping that's it.
  • djsilvus May 06, 2009
    Precise same problem with my unit -- plays DVD, but not Blu-ray. I'm hopeful a cleaning disc will solve the problem, but I'm not holding my breath. I know it's not an update issue, since discs that were playable no more than 3 weeks ago now are not. My purchase date was less than 1 year ago, but I don't have my receipt any longer.
  • ronorlando May 17, 2009
    Same problem so I guess I have a $500 DVD player. I have all the updates and new or old wont play BluRay only DVDs. Of course its about 14 months old
  • mark389 May 24, 2009
    Same problem.  Had it 18 months.  Plays DVDs fine - won't read Blue Ray Discs.  Doubt it's "dust" if the laser is working fine for regular DVDs.  Even used canned air from 12" away so as to do no damage.  Will be calling the Panasonic Repair Number.  If it's unfixable, or expensive to fix, will NEVER buy a product from Panasonic again!  $499 is a lot to pay for a piece of **** that breaks in 18 months.
I have had a similar problem. and Sometimes the discs will play then mess up a few minutes into playing.
I believe the problem (and my solution) is that there is dust getting on the lazer eye. Taking a cleaning disc and running it several times it has fixed it. It appears the dust gets on the Disc-Tray then transfers onto the disc, gets knocked onto the laser eye. I also cleaned the dust off the tray and have no had any issues, but will be watching out for anymore. It appears once the thing messes up that the units disc memory will not let the disc play any more because of improperly removing it without it de-initializing it. weird.
Until you can put some other blu-ray in there to wipe the memory.
Posted on Mar 26, 2009
  • Mafan100 Mar 26, 2009
    Awesome. Thanks for the update. This unit was given to me as a gift about a year ago. I don't have the receipt or anything like that. What did you need to send it in to them?
  • 140 Answers
Sounds like the DVD/Blue ray laser has gotten dust on it from being stored in a closet.
I would go to your local electronics store and purchase a cleaning disk. They are normally under $10. Insert it and run it though the player.
This sound no more serious than a dirty read laser.
Give cleaning a try.
Posted on Jan 29, 2009
There is no solution for this problem but a class action. Panasonic knows that this is a design flaw this the laser. Do a search on the net you'll find it's a common problem with this unit and Panasonic is doing nothing to fix the problem.
Like the others out here, this is my last Panasonic product. Incredibly poor customer service and flawed products. I won't be buying another Panasonic again.
Posted on Jan 26, 2010
DMP-BD60K Blu-ray won't read any disc after firmware update
Check with Panasonic---this is the risk you take when trying a update especially if the unit has no real problem......
Oct 16, 2012 | Panasonic DMP-BD60K Blu-ray/DVD Player
Upgrade BD30 wi-fi
To upgrade the firmware you will need to download the newest firmware from this site: and burn it onto a cd. If you can't or don't want to burn the cd it looks like they will can send a copy of it to you.
Mar 02, 2012 | Panasonic DMP-BD30K Blu-Ray Player
Dmp bd30 will not play normal. It will only play regular DVDs.
Unfortunately the problem is in the laser pickup assembly, the Blu-Ray DVD requires a higher velocity and precision to play this type of disc and is the first to fail. The only solution is to replace the DVD Player rather than have it repaired, far cheaper in the long run.
Oct 10, 2011 | Panasonic DMP-BD30K Blu-Ray Player
My Panasonic DMP-BD655 won't read any discs. I was fine a month ago but hen it wouldn't read Blu-Ray discs, but would still play DVD's. It stopped playing DVD's about 3 days ago. I have upgraded the...
Ive only had mine for 2 months and it just stopped playing dvds all together. I had a brand new dvd playing, went to switch it to another new dvd movie and it wouldnt read it or any other dvd Ive tried. I havent tried a blu ray disc yet.
Jan 02, 2011 | Panasonic DMP-BD30K Blu-Ray Player
BD30 makes a grinding sound when loading discs,
in most cases its a bad disc but if all disc are doing it then your glide tray needs to be re alined
Jul 04, 2010 | Panasonic DMP-BD30K Blu-Ray Player
For a blu-ray player model #DMP-BD30, how do we get updates
download this and put it on cd-r using a program like nero or whatever burning software your computer came with, then put the disc in the blu ray player, turn it off then back on and make sure it doesn't get interuppted
Sep 08, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Panasonic blu ray player ?
Hi , i just purchased a blue ray dmp bd30. i wish to use it as to play cds. It is connected to my 2 channel amplifier from the audio outlets, it is connected through the HDMI connection to a Pioneer PDP-428XDA. is it possible to play cds with the plasma turned off? I have folowed the instructions which describes turning off power from the options menu, but the options menu doest display?
Jul 01, 2008 | Panasonic DMP-BD30K Blu-Ray Player
Panasonic DMP-BD30K Blu-Ray Player Logo
3,863 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
