Question about Bose 3·2·1 II System
IT'S STUCK ON HOTEL MODE-Bose system
Mine does not record music, it's just a regular 321 system. I tried the enter then on/off, then press and hold enter. When I do this a display setting does not come up on the screen--nothing different happens. Any other thoughts?
  • darrinh830 Feb 17, 2009
    My Bose 321 system is stuck in hotel mode. the volume is at 15 which is not nearly high enough to hear. There is nothing in the manual about this so I am not sure what to do.
My bos systam its hotel mode so how to remove hotel mode
Posted on Apr 11, 2014
I followed the instructions that are posted on your web site again. The trick was to hold the enter key in, turn the on/off switch at the same time. Continue holding the enter key in, turn the on/off back on, hold for two seconds and then hit the volume down. It worked.
Thanks Marion
Posted on Jan 30, 2009
Bose 321 series ii remote control
try remote on your tv...hold tv button till it lights up and enter code for tv till red led goes out...then try it on tv..if it works,then your ir reciever is kerput...not your remote.i am trying to find parts for mine as well.
Oct 01, 2012 | Bose (321GS) System
There is a cd stuck in the system how do i get it out
This solution is from the troubleshooting section of the manual:
• Follow these steps:
1. Turn off the unit.
2. Unplug the Acoustimass module power cord from the outlet for 60 seconds, then reconnect it. This
allows the unit to reset itself.
3. Before powering on, press and hold Eject on the media center.
Hope this info may help you!
Mar 10, 2011 | Bose 3·2·1 II System
Volume is blocked ("hotel only"). How can I
I found this in another Fixya entry... "-Press Enter and On/Off on the media center , on standby mode -now hold the enter button pressed and start pressing the On/Off button. You should see a setting display on the player. The setting on display should change from video....till...Hotel Control -ON - on that position, press the Volume 'minus' button on the media center. It should change to Hotel Control - Off." My next suggestion would have been to call Bose and ask them why things like this aren't documented anywhere. 1-800-999-2673 Sales support: Mon. - Sun., 7 AM - 2 AM ET Technical support: Mon. - Fri., 8:30 AM - 9 PM ET Sat., 9 AM - 6 PM
REALLY - call them and complain that this is NOT documented online.
Mar 05, 2011 | Bose Lifestyle V20 System - black Theater...
Bose 321 system stuck at 30 volume
Is vol buttons button on unit do the same, try remote.
If not try unplug from wall wait hour and try agian, if not bose update cd..
Aug 02, 2009 | Bose (321GS) System
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
Stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Jan 16, 2009 | Philips RC2573 Remote Control
Cannot find a device code for ATT Uverse DVR cable box
1. Release the volume controls and assign them to the AUX: A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
Dec 28, 2008 | Bose Cinemate Digital Home Theater System...
Bose 321 System Stuck on Hotel Mode!
Hey, try this out
Thanks
Brigade
Sep 25, 2008 | Bose 3·2·1 II System
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Nov 13, 2007 | Bose 3 2 1 GSX System
Bose 3·2·1 II System Logo
605 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
