Question about Sony (LIB81A3BB) AIT-3 Tape Drive
SONY LIB-81 Error on LCD screen - Drive Information 51
Been having a number of problems with our Sony LIB-81 and Arcserve 11. Numerous errors on Arcserve Job Display Status: E6084 Drive hardware error - Servo or Sensor error [ABSL:3050 CMD:1Bh] E8005 Marking Slot[1] Off-line after media failure. Slot [1][SN:] in Library[3][SN:02585008] Several NT SCSI Port Errors. Have checked SCSI cables and IDs and nothing untoward there. Just don't know if it's the drive that's faulty.
  • 6 more comments
  • Anonymous Nov 02, 2007
    same problem here.
  • Anonymous Dec 01, 2007
    Drive Information 51 error
  • Davez Feb 13, 2008
    same here has anyone found a fix already?
  • jpwesty5 Apr 30, 2008
    Same as others but using BackupExec. New SCSI card and cable. New Tapes.
  • Anonymous Sep 23, 2008
    Guest17
  • Anonymous Sep 29, 2008
    Same issue. Loaded latest firmwares, new tapes, new cleaning tape. Ensured jobs were set up correctly. Backup will fail intermittently, and claim new tapes are bad. Drive information 51 comes up on the unit as well as Drive information 40
  • Anonymous Oct 24, 2008
    Same Issue
  • Chiefer Dec 04, 2008
    Same issue, with BackupExec
    New Friend:
What is the meaning of the message from sony lib 81 lcd " warning drive information 90.80"?
Posted on Jul 28, 2011
    Scholar:
  • 74 Answers
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Posted on Jun 12, 2009
SOURCE:
Screen on off often for no reason
There are some common problem for this model:
1. Power cycles on off with no error codes. (not screen on off) G1 board failure. Part # 1-468-980-12
2. LVDS cable failure my cause picture comes and goes. Part # 1-832-470-11
This information reference Sony tech support.
May 14, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tip
Sony Playstation PS3 Error 80022A07
The error 80022A07 is a widespread problem at the moment and has been happening since 11/11/09. This current error is actually caused by Sonys Servers and they are working on a fix presently.
According to Sony this error is occurring because of "Database and Server Overloads". This is blamed on the large number of Games releases and several updates being released at the moment and is not profile specific.
In other words too many people are using the servers all at one time.
The only thing you can do at present is wait until Sony have resolved the server issue as this is effecting the majority of users at present.
You can be assured that the problem does not lie on your end and hopefully this Tip will save you spending hours looking for a resolution.
If you found this information helpful please reflect this by using the ratings buttons on the page below.
Thanks for using FixYa.
on Dec 17, 2009 | Video Game Consoles & Games
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
Lib 81-AIT4 LCD message initizalizing Drive
tape drives is failure or the library can't find the tape drives. regards
Dec 04, 2008 | Sony (LIB81A3BB) AIT-3 Tape Drive
Sony kp 51 ws 500
· 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Hopefully, the descriptions of the blinking lights and the symptoms and problems will point you in the right direction to tell the problem with you Sony Projection Screen Television. If it is not enough, do not worry -- in the coming few posts I will talk about entering the Diagnosis and Service modes for your television set!
Feb 15, 2008 | Sony KP-51WS500 51" Rear Projection...
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
AIT ERRORS
I had/have a similar problem with a SONY SDX-700C.
Emailed Sony tech support (very helpful) who suggested sending them the diagnostics from their TapeTool utility (qv). They then recommended running the cleaning tape 3 times, which seems to get it working (but the 'clean me' light still comes on every 7-10 backups). Hope this helps.
Jan 18, 2008 | Sony (SDX-460VRB) (SDX460VRB) AIT Tape...
Event ID 11
Please perform a erase operation and check if the drive does it, If its not then go ahead and check the SCSI controller if you have a spare one replace it.
Aug 22, 2007 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
Event ID 11 error
Wonderign if you tried to install this on the RAID controller....big nono and cause this very issue...try a different SCSI controller...hopefully you ahve one onboard NOT raid. hope that helps
Aug 17, 2007 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
Error with DAV-S500
Sony DAV-S500 error c-81: On the rear side of the DVD board connected to the DVDv drive is a power transistor Q002 that is shorted BASIS-EMITTER. The device is an Toshiba 2SA1213Y (PNP transistor 1$) Replace and your DVD works! good luck :) Foxi from Budapest, Hungary, Europe
Jun 11, 2007 | Sony DAV-S500 System
Open Questions:
jhgj~$^ Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ CAnaDa how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 22, 2019 | Amazon Computers & Internet
* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}* [email protected][email protected]*@Avg phone number {1;888;499:552o*;-}
Oct 22, 2019 | Computers & Internet
See all Sony (LIB81A3BB) AIT-3 Tape Drive Questions
Sony (LIB81A3BB) AIT-3 Tape Drive Logo
1,959 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
