Question about Dell P1130 21" CRT Monitor
Shadow Lines Across Screen on Dell P1130 CRT Monitor
My monitor has developed shadow like lines across the screen in the past few days. It is a Dell P1130 running on Windows 2000. The video adapter is a nVidia GeForce2 GTS / GeForce2 Pro. I haven't added or deleted any software. I tried another monitor with the same result. Software conflict? How do I figure out what is going on?
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Posted on Jan 29, 2009
Lines and shadows across the screen
I would try it on another PC first, also check the VGA cable connectors at both ends. It can be that the filter caps in the power supply are failing inside the monitor.
If you decide to open up the monitor, please look through my albums so you will have some idead what to look for inside.
Apr 24, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Moving shadow bars - on applications & windows only
hi, generally it happens when an video card is faulty.. try replacing the video card,, it should work fine..
Sep 27, 2009 | Dell P1130 21" CRT Monitor
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Horizontal ghost lines across screen
Seems that it is an issue with your video card, Please update Driver for Video card and it that does not help, it is the time to replace the Video card.
You can get your driver from and please enter your service tag to download the driver
May 25, 2009 | Dell M781S Monitor
I have a Dell P1130 monitor running on Windows 2000 the adapter is a nVidia GeForce2 GTS / GeForce2 Pro. The past few days the screen is almost unreadable. It has dark lines (shadows). I tried another...
Sounds like an adapter problem.
If you have tired mutiple monitors then the card/adapter is the only problem/cause left.
You need to replace the adapter/card or motherboard (if the video is on-board).
There is not other reason. Drivers and updates will not help.
Jan 29, 2009 | Dell P1130 21" CRT Monitor
Black & White lines across my monitor
1.Make sure all the connections are secure.
2.Try attaching the monitor to a different PC if possible, to determine if its the monitor or video card.
3.Your monitor might just be going bad
Jan 04, 2009 | LG Studioworks 900B 19" CRT Monitor
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Problem with shadows showing on monitor
LCD Monitor Shadow Effect
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this is very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Open Questions:
Dell P1130 Blue Channel Problems I've had this monitor for over 4 years now - and it's been going strong since 2002, according to the manufacture date. Over the last year it's health has declined, and the blue channel used to flicker and strobe and pop at me when I switched it on in the morning, but calmed down after a moment and was perfectly normal for the whole day. Recently I turned it on after a couple of days away, and it was yellow - the blue channel didn't even seem to turn on with the rest of the monitor. After trying a few things, including some careful blows from my open hand to the sides, I pulled the plugs out and set it face down on the carpet, and went to find a screwdriver. I cam back, looked at it, and thought - I'd better find out how to discharge the capacitors before I do this. So I set it upright and switched it back on, but this time the blue channel popped on and did it's flickering thing! Almost as though turning it face down fixed it. That state has lasted for a couple of days - and the blue channel has worked ok, but when I switched it on this morning, the blue channel woke up, but then didn't cough into life, so now it's a yellow screen again. I took the back off and vacuumed the dust out, looking for scorch marks and leaking capacitors, but I couldn't see any - my guess is a loose wire leading from the power supply to the electron gun is loose or something like that. I love this monitor a whole lot, and because of it's superior color depth, I haven't wanted to get an LCD until I really had to. What I would like is an explanation of how the blue channel is wired to the electron gun, so I can check for loose wiring, and possibly a leaking capacitor that I haven't noticed yet, as well as the location of the capacitors inside the monitor case. I've been very careful - I've read a few articles on the subject, and I avoid touching anything except the outsides of the case. I know not to mess with things I have little knowledge about. However what I'm looking for is just some information about the blue channel's wiring arrangements, so I can check for loose wiring, or leaking capacitors, or shorted circuit boards.
Nov 23, 2011 | Dell P1130 21" CRT Monitor
Dell P1130 21" CRT Monitor Logo
1,112 people viewed this question
Alun Cox
