Question about Whirlpool Refrigerators
I am trying to replace the water filter (4396510P)
And I cannot get it to go all the way in. The latches on the cap are not meeting with the grooves on the cartridge chamber.
  • 65 Answers
ONE THING I HAVE SEEN QUITE A BIT IS THE PROTECTIVE CAP ON THE NEW FILTERS. MAKE SURE IT HAS BEEN REMOVED OR IT WILL NOT SEAT PROPERLY. HOPE THAT HELPS.
Posted on Jan 29, 2009
Can't get new filter installed
they can be a little stiff, but first things first. It may sound obvious, but check that you removed the cap from the filter and that it's not stuck inside the filter housing. if that isn't your problem, then you just need to be a little tougher with it. when you slide the filter in, you should feel it find it's groove, then it twists to the right a half-turn. you can try removing the front grill to get a better grip on it
May 06, 2012 | KitchenAid Whirlpool Kitchenaid Water...
Tip
My Dishwasher is Leaking
This advice is dishwashers exhibiting leakage around the door. In the majority of cases this may be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
The silverware tray (if located along the left or right side) can also contribute to causing damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub.
Some other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being diverted over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of over $100.
2. Replace the door seal at a cost of about $35-$40.
NOTE: I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
NOTE: Some manufacturers include a gasket epoxy that is applied to the gasket before seating. If your gasket does not come with this sealant, it does not require it.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges.
on Mar 07, 2010 | Dishwashers
When changing the oil filter on the 2002 tdi does the bottom (small) o ring go on the bottom or upper groove of the filter holder shaft?
on the bottom of the oil cap stick there are 2 places it seems possible to put the o-ring. If you are holding the cap as it would sit installed, with cap on top and stick hanging down the o-ring goes on the bottom groove, the thicker of the two
Dec 22, 2009 | 2002 Volkswagen Jetta TDI
After dishwasher was in cycle, I returned to kitchen and found puddle of water on the floor in front of it, water leaked down to basement. Haven't used since. Tried starting a cycle, but afraid to allow...
The symptoms you describe, sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
If you need parts, they can be purchased from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is usually listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
If you have questions, or require additional assistance, please post back with a complete model number so that I may be able to provide you with better service. hope this helps you.
Nov 10, 2009 | KitchenAid 24 in. KUDP02FRSS Stainless...
How to change door seal
Replacing the door seal on most dishwashers is very simple. Just follow these steps:
Oct 14, 2009 | Kenmore 24 in. 17372 / 17374 / 17379...
No spin cycle, stopped running
Hello, sounds like this is going to be a pump issue, take the lower panel on the front off the machine, there you should see something that resembles a gas cap like on your car. It will be located some where near your pump...Unscrew this cap making sure you have some towels handy to mop up the water that runs out. Once you have pulled out the cap attached you should find a filter cage. You will likely find a bunch of debris,coins,lint and other stuff blocking the pump. Replace this cap or filter and plug machine in and try again, You should be good to go. If this does not fix the problem you are going to need to replace the pump. p.s not sure why you are looking to replace the door latch since you mention the machine is not spinning. The door latch has nothing to do with the spin other then locking. Good Luck!! if you have any toher questions or concerns please feel free to comment again. Mike
Jul 20, 2009 | Frigidaire GLTF2940E Front Load Washer
Door Latch has broken plastic tab
The door latch assembly comes as one piece. It would actually be much simpler to purchase the new latch and replace the whole assembly instead of trying to put pieces and parts back inside a latch that may or may not work after all your hard effort. If you decide to replace the latch, follow these steps: 1. Unplug the machine. 2. Remove the lower kick plate panel if you like (this can help you reach the latch from a couple of different angles). 3. Open door and feel around the rubber door boot for a wire hoop. At the bottom of the door open is a tension spring. Pull the spring apart and remove the wire hoop from the groove. 4. Gently lift the rubber boot from the groove around the door opening and push inside the machine so you can access the inside of the casing. 5. The door latch assembly is located inside the case on the right-hand side. There should be a couple of wire connectors going to it (remember how they come off). Be careful with the wires, they are small and can break. 6. Unplug the wire connectors and remove the three screws holding the latch in place from the outside of the casing. 7. There should also be a plastic retainer holding the latch in place. Remove latch from retainer. 8. Install new door latch by placing it in the plastic retainer, first. 9. Plug wires connectors in. 10. Re-install the three door latch screws. 11. Re-install rubber door boot around the door opening. Make sure it is properly seated in the groove. 12. Reinsert wire hoop. starting at the top of the door opening, carefully push the wire hoop into the groove and work your way all the way around the bottom where the tension spring would be. (A second set of hands to hold the wire hoop in replace would be handy at this point). 13. Pull tension spring apart and snap into groove. Done. Hopefully this will take care of your problems. Of course, you may not like the idea of having to purchase a whole new door latch assembly, or the effort required to remove and replace. But, it sure beats trying to rebuild the old one. I hope this helps.
Jun 10, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step
5
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Jun 08, 2006 | Kenmore 15129 Built-in Dishwasher
Refrigerators Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
