Question about Kenwood KAC-8152D Car Audio Amplifier
Kac-8152d powers on, but no power output to subs
I have a kenwood KAC-8512d amp and i had it professionally installed to power two 12" kickers. It worked great for about a year or so and while ill was driving one day, my subs just quit working. I thought it was faulty wiring from the amp to the subs so i got new and better wire and hooked em up and got nothin. Moral of the story is, the amp's power light shows that its on, but it does not put out any power and ive checked its fuse and its good. Any suggestions?
    Problem Solver:
  • 6 Answers
Well, the sad thing is, it can be a number of things. You will have to do a process of elimination. Try replacing the amp first, borrow one off a friend. Second try replacing the subs. If those don't work, read the manual to your deck. Find the audio settings, and check to see if the sub section is "on".
Posted on Jan 29, 2009
Bridging two12" subs and one 15" sub to my Rockford fosgate T 1500bd amp
assuming all 3 subs are 3-4 ohms, running all 3 in parallel (the 3 positive leads all attach to the amp positive terminal, and all 3 speaker negative leads connect to the amp negative terminal) will bring you at or above 1 ohm, which the amp is capable of handling. With 1500 watts, you will want to use 8 gague power leads for the amp, 12 gague speaker cables, and an inline 120 amp fuse between the amp and the battery, within 1 foot of the battery.
Jan 11, 2017 | Rockford Fosgate Car Audio & Video
Do you need to connect the yellow and red wires together if not used in a car on a pioneer DEH-X1950UB
Yellow - Connect to the constant 12 V supply terminal.
Red - Connect to terminal controlled by the ignition switch (12 V DC).
Jan 11, 2017 | Pioneer Car Audio & Video
With the Uniden UH7700NB How do I tell which is positive and negative on the power input THANK YOU
You can connect the radio to any standard 12 volt DC power source, with either a positive or negative ground. If you don't know whether your power supply uses a positive or negative ground, consult the manual for your power supply or contact the manufacturer.
Jan 10, 2017 | Car Audio & Video
I have a Sony STR-KM7 AMP and the subwoofers have stopped working?
Sorry but it sounds like the subwoofer voice coil has shorted, you will need to replace the sub.
Jan 08, 2017 | Sony Car Audio & Video
How do I reset a Kenwood KDC-24BU flashing "PROTECT"?
Take of your positive battery cable. This should erase all your memory, since the car has no more power.
Jun 01, 2014 | Car Audio & Video
How do I reset a Kenwood KDC-24BU that is flashing "PROTECT"?
Replace the blown/shorted amplifier output Mosfets that are causing it, and it will then be happy to reset itself :)
No power to amp
check and try finding another grounding spot
May 16, 2010 | Lightning Audio B4.250.2 Car Amp
Lightning audio b150.2 as soon as +12 is hooked up blows 25 amp fuse and the c2 1000uf/35v capacitors blow???????
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you.
Aug 25, 2009 | Lightning Audio PC2 Capacitor Car Audio...
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
Car Audio & Video Logo
218 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
