Question about Sewing Machines
Winding bobbin in singer model 9117 sewing machine
How do i wind a bobbin for a singer model 9117 sewing machine?
  • billie1218 May 25, 2009
    when i try to wind the bobbin the tread winds beneath the bobbin and does not go on the bobbin
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
  • 106 Answers
SOURCE: Singer model 7462 sewing machine
Sounds like there is thread around the bobbin winder shaft and the machine is unable to continue winding, needs stripping and looking at. This is not something you should attempt yourself unless you know what you are doing. A reasonable sewing machine tech should be able to sort it out in a few minutes.
Posted on Mar 28, 2008
SewTechWayne
  • 186 Answers
SOURCE: problems winding bobbins on my singer 4622 sewing machine
I have two possible solutions:
1. you have the wrong bobbin and it doesn't grip the winder.
2. the small spring on the winder spindle is missing or bent, it is what applies pressure to the bobbin for winding.
good luck!
Posted on Jan 31, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 139 Answers
SOURCE: Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 16, 2010
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Model 9117. How do I wind the bobbin?
this question is under the singer category,, so here is a link for a singer manual,, http://www.singerco.com/uploads/download/410_317218001.pdf
May 26, 2015 | Singer Sewing Machines
How can we wind the bobbin singer sewing mashin model 9117?
Here is a link to a free manual for this machine. Page 9 shows how to wind a bobbin.
Sep 02, 2014 | Sewing Machines
How to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Jun 13, 2009 | Singer Sewing Machines
Sewing Machines Logo
676 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
