Question about Frigidaire FRS26R4A Side by Side Refrigerator
I'm trying to replace the water filter (4396510P). I have removed the old filter, but I can't get the new filter to go in all the way. Is there a secret that I don't know?
  • 140 Answers
No secrets... just press "up" and twist clock-wise.
Posted on Jan 29, 2009
Replaced filter and now water not working
Try removing and replacing the filter. If this does not work, and if you have the old filter, replace the old filter to see if the problem is resolved. If it works with the old filter, the new filter may be bad - so contact the seller for a replacement.
Feb 21, 2015 | Refrigerators
Removed and replaced the water filter from the base of my fridge and know I have an intermitent water hammer. Any ideas?
The new valve may not be so new. Anti-hammer water valves have around for decades, so if you replaced your old valve with a new one that hammers, take it back and request a anti-hammer valve. For some reason, hammer valves have made a return, get rid of it before it breaks a water line.
Jan 06, 2018 | Kenmore Top Freezer Refrigerator
Amana model# SZD23VE refrigerator were is the water filter? or does it even have a water filter?
Yes it has a water filter option. The water filter housing is in the refrigerator near the top of the unit. You need to twist the old filter itself to the left to remove. (You will be removing a cover that you need to take off the old filter and put on the new filter. This cover can also be replaced without a filter to bypass the filter. The part number for the filter is AP4310541, .
I hope this helps.
Apr 09, 2011 | Amana Refrigerators
How do I replace the water filter? No owner's manual is available
The water filter cover is the round thing you see in the toe grille beneath the freezer. It will have a handle that should be horizontal. To remove the filter, turn the handle counterclockwise 1/4 turn, then pull it out. If you have trouble, try removing the toe grille so you can get better access to it. Once you have it out, be sure to take the handle off the old filter and on to the new filter. Be sure to remove the red cap on the pointy end of the filter, then stick the filter back where the old one was. Be sure to push firmly when you turn the filter clockwise 1/4 turn. After you have the filter installed, be sure to take a big glass and run the water for a few minutes.
Aug 19, 2010 | Whirlpool ED5VHGXM Side by Side...
How to replace the filter
Take the new water filter out of the box and remove the two red shipping caps on the end of the filter.
The water filter is located on the front panel down near the floor.
Push the release button located just to the left of the water filter grille cap, this will release the filter.
Remove the grille cap from the filter by twisting it counterclockwise.
Reinstall the grille cap on the new water filter.
Insert the new water filter in the refrigerator making sure the words on the filter are the correct side up.
Push the water filter in until it clicks in place.
Flush Water After Installing New Filter
Be sure you flush out the water from the new filter after you replace it! Many readers are having trouble with airlocks because they are skipping this important step. Kenmore recommends you run the water out of the water and ice maker for a few minutes to flush out the new filter. This also helps remove air bubbles from the system. If you don’t do this it’s possible that the water dispenser may not work properly due to an air lock.
This particular water filter claims to reduce:
Cysts and turbidity – linked to gastrointestinal problems
Chlorine – taste and odor for better tasting water
Sediment – for clearer water
o-Dichlorobenzene – linked to risk of liver, kidney, or circulatory system problems
Benzene – linked to increase risk of cancer and anemia.
Note continue changing the filter on a regular basis.
Hope this helpout....
Aug 01, 2010 | LG Refrigerators
I have replace my water and the waer has stopped
Remove the new filter and re-instal. If this doesn't solve problem I would put the old filter back in and try. If you now have water remove the old and try the new one again. Don't forget to push firmly as it may have not seated fully.
Jul 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water Filter removal/installation
Bought the filter replacement and read the instructions. Turn off ice maker and replace filter. Remove by turning 1/4 turn to the right. pull out old filter. Remove cover, slide off, replace cover by sliding on the new filter. Push new filter in to the holding, hold so cover is horizontal, push in and turn back clockwise till the cover is horizontal to the floor.
Feb 02, 2009 | Whirlpool GS6NBEXR Side by Side...
I am trying to replace the water filter (4396510P)
Jan 29, 2009 | Whirlpool Refrigerators
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
99 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
