Blury ,double vision, and cant brighten up
I have a 50UX7B/K/W or 46UX7B/K and the picutre is blury and kind of a double on the right, and now i also can figure out how to lighten it, the book says to go menu, but cant find a place to get to brightness or contrast or tint etc.
  • 3,459 Answers
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Posted on Jan 29, 2009
Double vision screen
This is most certainly a display problem, as in, a problem with the LCD panel. I used to fix 4 or 5 LCD's a day and had a few with the same problem. It can be fixed by being replaced.
Jan 06, 2014 | Computers & Internet
My philips big screen tv is blury with double vision on words
Convergence, Convergence!
see attached photos--if looks like that it needs two chips and/or a few resistors replaced--total parts cost at say SUBURBAN ELECTRONICS under 25 dollars.
look at the photos here=look anything like your problem?
Mar 27, 2012 | Philips Televison & Video
We had a power surge now our picture is blury like double vision
There is a bad capacitor on the power board of the television that is why you are having the blurry double vision on the television. Have the power board checked for bad capacitors that need to be replaced.
Hope this helped. All the best Elect_Comp
Oct 09, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
Ive had my ematic mp3 player for 2 days and now the screen just barly glows but you cant see anything.And you can still here music
ok well when you can see the menu the best go to options then to display then there should be an area that allows you to brighten or darken the screen turn it up then it should fix the proublem
Mar 07, 2011 | XO Vision Ematic EM108VIDB Digital Media...
Our tv is blury, double vision with whites going
There seems to be two problems with the unit. The first symptom indiates your convergence IC's needs to be replaced. The second symptom coud be a several things, 1. Bad connections on the Crt board of the green tube, 2. The 200v screen bias voltage supplied by the flyback could have bad connections on it. Seems you have intermittent cold solder joints. Check the D board around the Flyback area for bad connections, or old grey looking solder connections all should look shiny. 3. The Green Crt maybe going faulty, the lines going thru the picture are scan lines and indicates that the Screen controls are to high. But i know you have'nt adjusted these so i would suspect the Green Crt is Faulty. But check solutions 1&2 first, One way to find out if its bad is to unplug the green crt board from the tube and turn the set on if it stays on and does'nt shut down then it is faulty, also while turning on look at the crt's neck for sparks which indicates arching in the tupe and will need to be replaced. Replacing the Convergence IC's will solve the distorted pic issue.
Nov 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Double vision
what kind of tv?sounds like a convergence circuit problem.
Mike
Jan 09, 2009 | Televison & Video
Jvc model av-56wp74
Needs convergence IC's replaced..........T.
Oct 06, 2007 | JVC AV-27850 27" TV
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Electro Med Services...
