Question about Kicker IX404 Car Audio Amplifier
Sound turns off
Ok so i have this amplifier in my car also and so rarely when i make a hard turn the sound in my subwoofer shuts off and then turns back on when im completed my turn is this anyhow related to a problem with my amp or something else???
    Novelist:
    Champion:
  • 219 Answers
Check all of your electricial connections, especially the ground. I wouldn't suspect anything internal to the amp is the problem.
Posted on Jul 26, 2007
Ok have figured out that it is not the speaker,
if speakers are ok the amp is faulty
Oct 17, 2014 | Car Audio & Video
My jvc RX-5020 VBK IS NOT WORKING AT MAX VOLUME,ON SCREEN APPEARS OVERLOAD SOUND STOPS AND I HAVE TO TURN IT OFF AND TURN IT ON AGAIN ! WHAT IS GOING ON???
You must be using speakers with lower impedance than what is recommended. This causes the amplifier to over load at high volumes.The protection circuit shuts down the Amplifier to prevent further damage.
And please remember no amplifier is designed to run at full volume, same as a car speed - Even though the speedometer might show max: speed 200Miles per hour would you do it???
Jun 19, 2011 | Car Audio & Video
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
Heard a knick-knack sound and then the engine shut
knock sensor is working at least right but unfortuanantly thats all that is working
it is likely a knock isue check the motor oil it is not un usual for a nisan to knock when the oil is low but on rare ocation it will kick so hard the knock sensor will activate
Mar 23, 2010 | 1994 Nissan Quest
No sound coming from subs
You definitely NEED a source signal for the amplifier to amplify!
You should have a Main Power Wire, a Ground Wire, A Remote Turn on Wire, and RCA cables (or hi level speaker wires if your amplifier has them)
and the speaker wires to the subwoofers.
Thanks for using FixYA - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2009 | Kenwood Car Audio & Video
Ok . i have a pair of crossfire subwoofers, @
Your amplifier is 4 channel... and only 2 ohm stereo capable.
You will get the most power putting 1 subwoofer wired in parallel on each BRIDGED channel.
This will give you a 2 ohm stereo load.
Both + on 1 subwoofer to + terminal on amplifier bridged channel 1
Both - on 1 subwoofer to - terminal on amplifier bridged channel 1
Both + on 1 subwoofer to + terminal on amplifier bridged channel 2
Both - on 1 subwoofer to - terminal on amplifier bridged channel 2
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | DHD NTX-3102 Car Audio Amplifier
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Jul 13, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
NO SOUND
check to see if the rca's have been disconnected from the amplifier or behind the head unit. if ok, thake a power meter and measure speaker outputs on the amplifier to see if voltage is present. can also check resistance on subwoofers to see if they are blown.
Jul 12, 2008 | Car Audio & Video
Subwoofer has power but not getting sound
Some ideas.
Blown fuse in the amplifier section.
Dead amplifier
Dead speaker.
Amp is not that expensive, call Velodyne
Apr 29, 2008 | Velodyne CHT-10 Subwoofer
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Kicker IX404 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
