Question about Brother HL-2030 Laser Printer
Just won't print
I don't know how else to explain it but the printer only prints when it feels like it. I cannot get it to print. Sometimes pulling out the cartridge and putting it back in several times eventually gets it to print, but there is no method to this, it just prints if it's having a good day.
The toner light is on, but I know there is still toner because when it does print, it comes out fine. But would this affect it?
I've tried uninstalling the printer and re-installing it and still nothing.
Can anyone help?
  • lamngocapril Jan 29, 2009
    Thanks SibylSys! Just put the new toner in and it printed right away.
    Thanks for your help :)
    Problem Solver:
  • 19 Answers
It sounds like the toner is running low, basically when you pull out the toner cartridge it moves the toner around on the inside and enables it to print for the time being
Posted on Jan 29, 2009
Printer will only print purple
on a colour printer, black is mixed with the other colours. Try printing a black and withe photo and you always get a colour cast. If your black cartridge is empty or the nozzles are blocked, you get bad colour and fussy prints.
test all nozzles, like is explained in the manual.
Check, if you know how to do, if nothing fell in the printer, that is now on the print head. Sometimes just dust or paper scraps are picked up by the printhead, making it difficult for the printer to print a normal page.
Apr 15, 2014 | Epson PX730WD Stylus Photo
I don't understand the my printer was working perfect it pass the aliment but I turn off the printer for few weeks and now when I turn on my printer it won't print black it won't pass the
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 31, 2012 | HP Photosmart C6100 All-In-One Printer
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
While having a live chat i was informed the text would go to my print buffer....fine @! But I don't know what that is or how to access it. Can you help me ?
Hi
You don't say which operating system you are using.
The print buffer is an area where the printer stores a small list of the instructions given by the user ahead of what it is doing in real time (for example you can press print for 2 or 3 different documents while the printer is printing the first one and the printer will keep and remember the information for the subsequent documents in its buffer and print them in sequence, when it has finished printing the current document).
Feel free to add a comment to this question to explain the problems you are having with your printer, if this answer does not cover your specific problem.
Your printer has a small memory cache built into it that can store several pages of printing and print instructions ahead of what it is printing in real time. In the event of an error the memory cache can become full and be in a state where it accepts no more instructions.
If this happens:
Start (Contorl Panel) > (category View) > Hardware & Sound > Printer > double click on yhe printer's icon > highlight and cancel any documents pending > power off the printer > disconnect the printer cable > restart the computer > power the printer on > reconnect th eprinter cable > test print.
I hope this helps.
Aug 28, 2011 | Office Equipment & Supplies
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 15, 2011 | Office Equipment & Supplies
When I try to print I get an error and it won't print. The error message never shows up so I don't know what the error is. I have removed and reinstalled this printer 6 times now. I have rebooted...
Sounds to me like a bad USB cable,
Also when you're re-installing the printer are you using new/different drivers?
I would try a new cable and the latest drivers direct from Lexmark.com
Jun 01, 2011 | Lexmark X4650 InkJet Printer
Canon mp390 won"t print,on third print head in 12 mths still won"t work ,don"t know what else to do other than scrap it and buy a different make of printer
Hi. I share your frustration. Three heads in one year is unacceptable. I think your idea of purchasing a new printer is a good one. Look for sales and put this frustration in the trash as it must have a more serious issue going on. J.
Jul 20, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Crooked feed, sometimes won't pull the paper sufficiently down and I get an "out of paper" error message
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 21, 2009 | Dell 922 All-In-One InkJet Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Brother HL-2030 Laser Printer Logo
109 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
