Question about D-Link DIR-625 (790069292637) Wireless Router
Upload speed My upload speed is terrible. Need to use the router for VOIP and I am getting about a 2,000 kps download and 50 kps upload. If i am linked directly to my modem I receive about 5,000 download and 450 upload. Please help. I have taken hours trying to find out the problem
  • Jason
    Jason May 11, 2010
    Does the bandwith issue effect the VOIP? Have you enabled QOS? In most cases this will solve the VOIP Problems.
  • 4 Answers
Enable UPnP....UPnP can help make sure NAT works correctly for Xbox LIVE. Usually, this can be set on your router configuration web page, which is supplied by your router manufacturer. And, make sure UDP is open for the Xbox ports your using.
Posted on Jan 29, 2009
Speed on Verizon Fios
I had this problem or similar. Verizon (in New England area) upgraded my speed to 7MPS Download and 1MBS upload. It was slower than the old speed. I called in Verizon and after a lot of back and forth - well, to be fair, they were good - it turns out that the router on their site was old. They unplugged us from it and put us on a newer faster router and Voila! Worth a shot.
Jan 20, 2014 | D-Link AirPlus Xtreme G DI-624 Wireless...
Netgear N300 is slowing down my internet connection
The router limits the data speed to the wireless reception.
802.11 G speed (maximum) is 54Mbps.
Jul 17, 2013 | NetGear N300 Wireless Router
Slow upload speed
It is usual that the internet speed differs when connected to a modem and a router. You have many possibilities to get signal affected while connected through a router.
Anyway you can try with these basic steps to get a better connection through router,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.com before and after performing these steps.
Sep 12, 2012 | D-Link DGL-4500 Wireless Router
Fast download but slow upload. 2.0mb up and .05 down. Whats up with that?
its not the problem with the router, that download and upload speeds are monitored by your ISP (Internet Service Provider) so check with your ISP.
Mar 19, 2010 | D-Link DSL-504T Router
Well, it's my speed. It' extremely slow. I've tweaked settings, looked on-line and nothing. Here's what it's speed is at: http://www.speedtest.net/result/521763566.png As you can see, the connection is...
Your description of your setup sounds like you have things configured correctly on your end.
The only way to get a higher upload speed would be to contact you internet provider and ask if they have any residential plans that offer higher upload speeds.
Internet providers normally limit the upload speed available to residential customers in order to discourage them from operating web server and other services from their homes.
Naturally, if you cough up the money for a business account then the higher speeds become available according to what you're willing to pay.
I actually read the fine print of my ISP's "Terms of Use Policy" and it specifically stated that residential customers are not permitted to operate servers. Seems to fall right in line with the lower upload speeds available to residential customers.
Jul 21, 2009 | D-Link DIR-615 Wireless Router
Voip problems
Hello, there are several reasons too this, but the most common ones is:
- You have maxed out your bandwith.
Solution: Limit download and upload from filesharing. (need 256kBs free both ways to perform a good qualtiy voip call). Turn of web radios, webcams, video streaming. Encrypt wireless network
- Your Voip service provider cant keep alive registrasion link between their server and your voip device.
Solution: assuming you have both a modem and router, try to connect voip device directly to modem, if problem is solved you should try to upgrade firmware in router or by a new one (pref: Linksys). If problem still occures you should try to contact your broadband provider and get them to do a 24hr scan for datapackage loss on your connection (if they find datapackage loss, then its their job to fix the problem). If none of this works conntact your voip service provider and get them to send you a new voip device.
This is not a final solution, but it shold be a good guide to start with. i can give you much more detailed support on this issue, but then i need more details to analyse the problem further.
greetings
Jun 05, 2008 | Linksys PAP2
Download's speed
Speakeasy — Speed Test Test your internet connection speed!go to:
http://speakeasy.net/speedtest/
Speed Test — About Broadband Speed Here's some information to help you understand your results. There are a lot of things that factor into your speed test results. Download and upload speeds, backbones, networks, latency, ping times, and DNS servers.
Download
Download is a measure of how fast your connection delivers content to your computer or local area network.
Upload
Upload is the measure of how fast content is delivered from your computer or local area network to others on the Internet.
To achieve optimal delivery of T1 or SDSL services, download and upload speed should match or at least be very close. This is very important for applications like VoIP, email, on-line gaming and other interactive programs. Upload speed is even more important if you are operating an email, web or file server at your location.
Kbps
Kbps transfer rate = kilobit per second transfer rate. There are 8 bits in a byte, so we would divide kbps by 8 to get KB/sec transfer rate.
Apr 10, 2008 | Conexant Cnet 5614RV V.92 56K Internal...
Choked upload?
Hiya Masklin... go in to network connections... there will probably be 2 connections showing.. if you are the only user through your router.. disable lan 2.. trying to get two connections through same port.. which is more than likely at fault.
It will be the Ethernet connection that you need to leave enabled.. this should eliminate your problem ..
Regards Faggly
Mar 18, 2008 | Zyxel P660HW-D1 Router
D-Link DIR-625 (790069292637) Wireless Router Logo
290 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
