Question about XFX GeForce 6200TC Graphic Card
Toshiba Satellite R10 display glitch
Hello I have a Toshiba Satellite R10 and the screen just started randomly either blacking out or flashes solid colors across the whole screenand i have to do a hard reset
  • 1,602 Answers
The refresh rate maybe set to high
and or if you are doing anytype of overclocking
when it flashs how many times does it flash
are the short or long signals, or mixed both short and long signals together
Posted on Feb 28, 2009
I just bought new lcd display for my Toshiba Satellite R10 Tablet. The inverter is fine, checked the cables and reconnected. But the screen alternately flashes solid white, red, green and blue on the...
you need to download the proper drivers for the Graphics Card Right click your desktop go to settings go advanced Go to the intel(R) tab and hit Graphics Properties thin pick' either Dual Display Clone or Extended Desktop and Click Apply.
Wierdly the Monitor 2 will Still he greyed out in the settings Tab but the monitor will display Good luck
I'm currently trying to figure out it I Can Rotate the tablet Monitor and keep the other monitor Un-rotated Any ideas?
Oct 19, 2010 | Toshiba Satellite R10-S802TD Tablet PC
My battery will not last upto 50minutes and my applicayions stops
It may be overheating or you are running too many applications. Try shutting some down from the start up menu.
Aug 19, 2009 | Toshiba Satellite R10-S802TD Tablet PC
My Toshiba Satellite M305D-S4830's screen will flicker black randomly with no aggrevating and occasionally will fade to white or black completly.
I recommend you to reinstall the display drivers of your laptop as the issue may occur due to the corrupted display drivers.
Uninstall the display drivers from Device Manager.
Expand Display devices.
Right click on the display device and select Uninstall.
On restarting the laptop, windows will detect the device and reinstall the display drivers.
You can even install the display drivers from your notebook support website:
Jun 29, 2009 | Toshiba Satellite M305D-S4828 NoteBook AMD...
Hello, I have a Toshiba Satellite R10 laptop with XP and I just Started having an issue where the screen randomly glitches up and either just goes blank or starts flashing different colors across the whole...
Probably a driver issue. Try Windows Update and select custom. Maybe there is an updated driver available, or there could be a driver conflict (wrong driver installed). At worst, it could be an issue with your screen itself or possibly even the motherboard. But I doubt it. If you can't find anything there, try
Jan 29, 2009 | XFX GeForce 6200TC Graphic Card
Clean dust from tablet pc screen
I have an R10 tablet.
I once asked a Toshiba certified technician if I could remove the screen cover and I was told that I am not supposed to do that.
Maybe you shoul take the unit to a Toshiba repair center in your town, or country.
Hope it helps.
Jan 20, 2009 | Toshiba Satellite R15 Tablet PC
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website ( & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba P-30 Screen Problem
Well Jim, this could be a couple of things, a simple driver glitch, or a dead pixel area. Let's hope for the driver glitch. Start by uninstalling the video drivers from the device manager, then reboot. The machine will find the screen and reinstall the video drivers. Then readjust the screen resolution in the display properties. If the problem persists, then I'm afraid you have a dead pixel area. This will be caused due to a bad screen inverter or bad screen, then the inverter or screen will have to be replaced. It's very rare, but occasionally a loose or bad connector can cause this. You might also check the screen connections for a loose connection or a little dirt/corrrosion build up.
Jul 20, 2008 | Toshiba Satellite P30 P35 Series Notebook
Satellite R10 Wont turn on
clean off the heatsink and CPU fan.
Feb 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Problem with my tablet pc
The Satellite R10-S802TD doesn't have built in bluetooth device, however it's bluetooth compatible. any external bluetooth adapter will work. Toshiba recommends
PA3370U-1BTM Toshiba Bluetooth SD Card V1.2 or
PA3405U-1BTM Toshiba Bluetooth USB adapter as indicated you product's spec sheet.
Please post if you need further assistance.
Good Luck
Feb 06, 2008 | Toshiba Satellite R10-S802TD Tablet PC
XFX GeForce 6200TC Graphic Card Logo
164 people viewed this question
Top XFX Computers & Internet Experts
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
