Question about Sony Ericsson K700i Cellular Phone
FM Radio not working.
I was travelling through the rain. Though my phone was not in direct contact with rain but it caught enough moisture and gone off. After blowing a hot air for half an hour the phone again started working but some of its functions stopped working. Presently the main problem is it does not detect head phone at all thats why i am unable to play the FM radio. One more problem is when phone is charging and an incoming call is there the keyboard becomes very slow or sometimes insensible, also ringtone does not play smoothly, it sounds like on off on off and so on. Also the battery drains quickely.
I had the same problem, my k700i has since broken. When you make a call, if its the same as mine, you can't hear the other person right >
I simply restarted my phone over and over by taking out the battery putting it back in and starting.       I did this until i could hear music from the Media Player, From hear it should be in the normal mode, when you insert your head phones it should go to the handsfree profile. If it doesn't go to your settings and search for new devices. i do hope this helps
Posted on Mar 21, 2008
Does and how can I turn on the fm chip in my Samsung Galaxy Centura?
How can I listen to the FM radio on my Samsung Galaxy S?
www.samsung.com/uk/support/skp/faq/367871
Samsung ElectronicsTo listen to the FM radio, please see the steps below: ... Note: to access other functions of the FM radio feature please see the ... Turn the FM radio on or off.
Activate Your Cell Phone's FM Chip . About ' OPB
www.opb.org/about/connect/mobilefm/
Oregon Public BroadcastingWhy You Can't Access Your FM Receiver ' Why You Should Contact Your Carrier ' Contact AT&T ' Contact Verizon ' Contact T-Mobile ' Partners ...
Turn on the radio chip in galaxy note edge ' Verizon Wireless ...
https://community.verizonwireless.com/thread/860733
May 14, 2015 - Turn on the FM tuner! As a Verizon customer I request that youactivate the FM chips in all smartphones you sell. This is more than just a matter ...
AT&T Requests Android Smartphone Makers To Turn On ...
Dec 10, 2015 | Samsung Cell Phones
I have been having problems in heavy rains it miss out. now the engine won't crank. 2004 durango. the battery is good.
The moisture in the air is an obvious indication of a poor electrical connection/contact. You must inspect the ignition cap and rotor and replace if excessively worn.
Dec 22, 2013 | 2004 Dodge Durango
WHY IS MY RAIN TRAIN MOVING BACKWARDS
Hi there ... have you posted this question before? Not important ... I answered this question yesterday ...
ASSURE that the water arms are pointing in the proper direction. Normally, the arms should turn in a clock-wise direction to make the "tractor" go forward. If yours are going the other way, the tractor will travel backward. If yours ARE moving in a clock-wise direction and your tractor is going backward, reverse so the arms travel in a counter clock-wise direction. If it STILL goes backward, no matter which direction you are spinning, return the device to the store where you got it and ask for assistance.
I have this very device (though not this model number), though mine is LOTS older than yours is. I can make it go backward but it doesn't necessarily want to straddle the hose in reverse. All I do is reverse the direction the arms spin and vo-la ... it goes backward. BTW, I always store my tractor with the transmission in neutral to avoid damage by rough handling of others.
Jun 05, 2011 | Nelson LR Rain Train Traveling Sprinkler...
Want to get fm radio on my phone
Unfortunately, the i-mate 9502 doesn't have FM radio. I can think of a workaround for you, though, like the i-Tech Clip bluetooth stereo headsets with built in FM radio, which, besides being able to handle your calls (handy for such a heavy phone of yours, don't you think?) you'd be able to listen to stereo MP3s stored in your phone (as well as to its built-in FM radio). Take a look at them, and see if one of them fits your needs.
Cheers! Carlos
Apr 21, 2010 | i-mate Ultimate 9502 Cell Phone
I have moisture under the screen of my ifinder expedition c after getting caught in the rain. How do I get rid of it?
usually the displays are sealed so this doesn't happen.
About all you can do is open anything you can and then place it where it will be warm but not hot, out of direct sunlight and hopefully with some air movement. It might take a week or more before the water is gone.
I would also have a chat with lowrance and see if you can get this replaced under warrenty. If it leaked once it will again.
Mar 30, 2010 | Lowrance iFinder Expedition C Handheld GPS...
2003 Saturn Ion 2 with am/fm radio problems
I've got a similar problem with my Citroen C5. The satnav screen works sometimes and doesn't at other times. I've been told that it is probably the battery that is not holding enough charge. :)
Aug 28, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
2002 ultra radio. does not come on both fuses are
Unit is internally liquid damaged. Contact Radio Sound for possible repair.
(radiosound.com)
Aug 02, 2009 | Harley Davidson 426290 AM/FM Radio
Grundig S350 not powering on
Is there any easy self-fix that can be done to get the radio working again?
Nope. I'll bet you have some corrosion inside the switch itself.
Unless you can disassemble that you will have to send it in. If the switch had metal contacts, you could try just a tiny shot of cleaner in the switch, then work it off and on.
If you are able to get to the switchs' contacts, you can short those and see if the radio powers up. Just make sure that you have the right connections.
Bad idea bout wpraying it down with cleaner. If that suff gets in the coild or other parts like the tiny tuning capacitor, it can melt together inside, or at least cause it to be off frequency.
Good luck,
Apr 05, 2009 | Grundig S350 AM/FM/SW Radio
Sony Ericsson K700i Cellular Phone Logo
32 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
