Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Stopped Working Mid-Cycle
My dishwasher keeps beeping and flashing OE, the model number is LD-2120W. Can you please help?
  • brodieciesla Feb 03, 2009
    Told me what the problem was, was did not offer a solution on how to fix it.
  • Anonymous Feb 22, 2009
    SAME ISSUE....BOUGHT NEW...PACKED UP SOON AFTERWARDS....PHONE PHONE PHONE...LOOK ...LOOK...LOOK...EVENTUALLY REPLACED.....PACKED UP AGAIN...OE FLASHING...HUGE NOISE FROM PUMP..........THESE ARE RUBBISH...DON'T BUY ONE
  • 5 Answers
Blockage in outlet pipe
Chris
Lg durban
031-7165444
Posted on Feb 02, 2009
This is an outlet error can you hear it drain if you can check to see if the drain hose has a loop if you don't hear it you may need a new pump for dish washer i recommend best buys geek squad out to look at it their lg pros
Posted on Feb 18, 2009
Why won't the dishwasher drain?
Have you checked the hose?
Aug 12, 2014 | LG Dishwashers
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Our dishwasher keeps stopping its cycle and saying 'OE' It is LG - LD/141ST1
the 'OE' code means clogged or kinked drain line. You will need to pull the dishwasher and disconnect the drain hose from both ends and flush out debris at the sink. Be sure the hose isn't kinked.
Sep 22, 2010 | LG Dishwashers
Error code 0E
OE is OUTLET ERROR.
More often than not, a blockage is in the pump(not that easy to get to and quite a long step by step process)
You might also find the blockage at the end of the drain hose, where it connects to the drain pipe- remove the hose clamp and inspect hose and spigot.
May 04, 2010 | LG 24 in. LD-12BW5 Free-standing...
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error OE
thats a drain problem , blocked drain hose , drain pump stuck or burned , last case scenario electronic control
Jun 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
793 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
