Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
I have a Dell 1800FP monitor. I get no power lights at all
I have opened the unit up for a quick inspection of the power supply and here is what I found.
I have checked the AC through the full wave bridge - it is good.
I have 165 Vdc all the way until Q902 ( which I am assuming is a SCR??
Could the problem be in IC 901??
Does this power supply need to be loaded to get the 5 and 12vdc outputs??
I have hooked it up on a bench with no loading.
Any help or schematics of this thing would be appreciated
Thanks Rob
  • oceanaccess2 Jan 29, 2009
    why is it so difficult trouble shooting a power supply?
    I can do it without a schematic by ohming out the components one by one if necessary. A schematic just makes it that much easier. Once it gets to an IC and not a discrete component then that is a different story. I would rather replace a $1.00 transistor than the entire powersupply
  • Dell Master
  • 1,183 Answers
finding the fault in power supply is bit difficult , as it either works or goes bad . You can check this website for reworked power
supplies.
http://resurrectek.com/osCommerce/
Thanks
proton
Posted on Jan 29, 2009
How to solve NO POWER PROBLEM in DVD622
DVD power supply repair tips bridge-rectifier-repair.jpg?w=580&h=435
This demonstration fixes the power supply of a DVD player, but the skills transcend this one application. [Alan] walks us through the process of repairing a power supply (translated) on a simple consumer electronics unit.
Obviously this starts by cracking open the dead device and verifying that the culprit is the power supply. [Alan] then removes that board from the chassis and gets down to work with a visual inspection. He's got several images which illustrate things to look for; blistered electrolytic capacitors, cracked solder joins, scorch marks, etc. In his case there's obviously a burnt out fuse, but that merely protects the hardware from further damage, it's not the cause. Next he examines the diodes of the bridge rectifier. These need to be removed from the system to do so, which he accomplishes by clipping one end of each as seen above. He found that two diodes on one side of the bridge had broken down. After replacing them he tries a new fuse which immediately burns out. But a quick swap of the capacitors and he gets the thing back up and running.
troubleshot ^_^
Jul 04, 2014 | Philips DVD622 DVD Player
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
Dell 1800fq LCDcomputer monitor not coming up
More likely to have shorted out SWITCH MODE POWER SUPPLY IC, very common in this power supply. You can replace the power supply or buy a repair kit for this power supply on EBAY.
You should at least finr out if your are getting the 12vdc at the power supply output connector.
Replacement power supply module:
http://lcdrepair.us/1800fp-power.html
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 05, 2011 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I am facing a problem with my SMPS. When I press the power button, the LED, SMPS fan and processor fan turns on for a moment then goes OFF. I looked at SMPS PCB and found tht big capacitors had a chemical...
YES !!! As they have leaked their dielectric chemicals and are faulty. Replace them..And Replace both caps if a half wave rectifier bridge is what you have...And all 4 if you have a full wave rectifier bridge. ( 2 power diodes is a half wave Rect. and 4 pwr diodes is a full wave bridge. And 1 capacitor is used for each power diode... As a rule, locate the leaker and replace it AND the 1 that is closest to it that is EXACYLY the same as it is...Mfd rating, shape and size will be the exact same... Either 2 or 4 will be present...Depending on the 1/2 or full wave bridge...
Nov 04, 2010 | Computers & Internet
I have waveing in my tv
Hello
Picture waving can be due to many reasons. The first reason is ariel connection. Check it first for tight and not loose contacted. Second one is due to the main filter capacitor connected across the main rectified power supply DC. If the capacitor goes value reduced or opened, waves may occur. If this is the reason, picture will show blooming effect also. Check the mair rectifier bridge also. gopakumar1@hotmail.com
Oct 18, 2010 | Orion STV2763 27" TV
My monitor will not turn on. 1800FP
More likely to have failed power supply due to bad IC in the power supply. You can buy the repair kit or new power supply, you should check for the 5vdc and the 12vdc first.
Replacement board: http://www.lcdrepair.us
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 20, 2010 | Dell 1800FP Monitor
Video on 1800FP flashes on and off.
You need to check the output voltage of the power supply module to see if the 12vdc output is swtiching on and off, it can be power supply failure or it is sensing short circuits, it can also be the inverter board.
http://www.lcdrepair.us/1800fp-power.html
http://www.lcdrepair.us/1800inverterKUBNKM045A.html
http://www.badcaps.net
May 12, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
The picture does not com on but the monitor is on..some time it comes and goes but most of the time it is just black dell ultra sharp 23 inch
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Replacement boards:
Apr 18, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My ups cannot give backup when AC power fails no power supplied to PC then PC is restarted but i replaced a new battery but no result found. What is the solution for this problem ?
It sounds like you have a computer with an Active PFC (Power Factor Correction) Power Supply.
Back-UPS units, when running on battery power, output a Modulated / Stepped Sign Wave. Active PFC Power Supplies are NOT compatible with this pseudo-sign wave power, which is the reason it will not stay running.
You need a Smart-UPS unit, capable of delivering a true sign wave when on battery output.
Feb 13, 2010 | APC Back-UPS 400VA (BK400) UPS System
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
296 people viewed this question
Alun Cox
