Question about Logitech MX 700 Mouse
Still flashing Sorry, I didn't mean that your suggestion was not useful, but I don't use rechargable batteries, so really it didn't help me out much for I wasn't even able to try that. I am now only able to use the mouse for a few seconds at a time, i then put it on the charger it will flash green about 5 times then flash a faster red I then have to press the connect buttons on the mouse and receiver each time i use it and then can only use it for a few second again. I'm going crazy. Thanks again
  • Franca Pachi Jul 28, 2007
    thank you. I worked it out to be the batteries and bought rechargeable ones and I am no longer having any problems. Thanks for all the help.
  • 41 Answers
I have this same mouse and as I recall, it is recommended that you use rechargeable batteries (like the ones included in the package) with this mouse. If you use regular batteries in the mouse and then put it on the charger, it will most likely ruin those batteries and possibly the mouse over time.
Posted on Jul 27, 2007
  • Anonymous Jul 28, 2007
    You're welcome. Glad I could help.
SOURCE:
I need the restriction code so i can use a different sim ??
Sorry I completely misunderstood. I didn't get the whole video thing, I've never really used the site. Sorry again, but I don't think I can help.
Nov 04, 2012 | Cell Phones
Car will not start
A simple jump start with battery cables should get the car started and recharge the battery. If you don't like dealing with battery cables, there are products that attach from inside the car using the cigarette lighter to jump start the car that work very well.
Oct 28, 2011 | 2008 Toyota Prius
My battery charger stopped charging the battery. Whenever I put the battery in the charger the green light flashes signaling a problem. I tried wiping the contacts as the book suggested but with no...
How long do you have the camera?
Rechargeable batteries don't last forever, and when they are too weak to take a charge, the little light just blinks.
They could also be shorted out.
This flasing is a problem code. "The book" should also tell you what these flashes mean, although it usually means: replace the battery.
Jun 24, 2011 | Panasonic LUMIX DMCTS2 / DMCFT2 Digital...
My batteries died so I recharged them but now the remote will just flash on the tv button. It will turn the volume up or down sometimes. It will change the channel every once in a while but its not...
Hi drembert35,
Try dis-assemble the remote control, and clean it from inside, using Akia Spray or something, but be carefull to not use cleaning fluid which would erase the button connection with the board, so just use spray, and if you don't have one, use the water, and dry it fine before connectng the battaries to it.
and see if the buttons work fine, after doing this, and if not, do this,and don't get surprised,
use a cigarette package paper, the silver paper, and cut a circle from it, in the size of button, and put the conductor side of the paper on the board, on the buttons which don't work with you, and fix it good, then assemble the remote again.
that's if not the 1st soultion of cleaning didn't work.
and Let me know.
Jun 11, 2011 | Philips RC4331/01 Remote Control
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
Quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
Jan 12, 2009 | Fuji FinePix S7000 Digital Camera
D50 Battery & clock icons flashing
well i had only the clock icon flashing and after setting the date and clicking an enter on it disappeared my battery icon's all good...about the battery thing i would recall what happened before the icon started to flash might be helpful maybe the inner spring got a damage or the upper sheet metal or membrane as you please has something... cause it happened to me couple of years ago but it got solved and i cannot remember how sorry...definitely there is an easy solution cause i had not had to take it anywhere...
Nov 23, 2008 | Nikon D50 Digital Camera
Ds nintendo will not charge light flashing and think it is the connection on the ds as i have tried other chargers in it
um.... im jut asking dose it flash green, orange or red? if it flashes green it is fine if it flashes orange its giving you a warning then if it flashes red that is when you charge it oui? but if it flashes red and you still cant charge it well i ont know what to tell you? oui, no, maybe? wll if i didn help sorry but i tried. sorry or your welcome which ever best fis your dicription. †
Dec 01, 2007 | Nintendo DS Console
NIkon Coolpix 2100 Digital Camera
Change the setting off from automatic. Choose Flash for all your pictures.
Artgirlny
Aug 31, 2007 | Nikon Coolpix 2100 Digital Camera
Logitech MX 700 Mouse Logo
166 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
