Question about Pioneer PureVision PDP-4330HD 43 in. HD-Ready Plasma Television
Pioneer pdp-4330 turn of automatlic and apper E01
My tv turn's off automaticly and I have to remove the power cable and plug it in again and it turns on again but the code E01 appeares which means the conection cable is wrong, i need help I don't know if it's the clables or my reseiver is the problem?
  • 4 Answers
SOURCE: pioneer pdp 5080xd
put a pack of smokes direcly in front you wont see the lite anymore
Posted on Dec 14, 2007
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
  • 22 Answers
SOURCE: pioneer pdp-v402 40"
Posted on Jan 12, 2008
SOURCE: pioneer plasma tv pdp-503pu 50"
Posted on Aug 08, 2008
  • 3 Answers
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
hope this helps mark doran
Posted on Mar 17, 2009
Pioneer pdp-4271 plasma will not turn on, tried unplugging it and letting it set and plugged back in not turning on, i have checked the outlet for power and it is good also checked end of plug that...
The tv have a power supply board problems.That the board,where the power a/c cord plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Oct 19, 2010 | Pioneer PDP-4271HD 42 in. Plasma...
Pioneer pdp-ro3u pops up E01 then shuts off
reset the device by unpluging the device for somr minutes and then again replug and see if it works.
Oct 28, 2008 | Televison & Video
I turn my Pioneer plasma HDTV on and it kicks off.
Way too many possibilites can cause this. The most common is a problem with the Plasma panel. Sorry. Best to get an estimate and get a price on the estimate cost. A free estimate will be worth the price - use a Pioneer service center.
Mar 30, 2010 | Pioneer PureVision PDP-4330HD 43 in....
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
I have an E01 error message what is it and how do I fix it
I have an E01 error message what is it and how do"tv pioneer pdp-503pe"
Nov 20, 2009 | Pioneer PureVision PDP-503HDE 50 in....
The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Aug 19, 2009 | Televison & Video
Plasma e01 error
Hi. Had all the symptoms with my Pioneer 43" plasma with RO3E receiver that have been previously posted. I got so fed up with it turning itself off that i decided to take the top off the receiver and look for the dry solder joints on the power supply board that some have posted to have cured the problem. I removed the power supply board (which involved removing an interface unit which is mounted above it) and found no issues. I then proceeded to remove the switch board which is placed in front of the power supply board. When i removed the electrical connector which i found not to be fully inserted, i noticed that there was a brown burnt stain in the middle of the connector plug indicating a possible poor connection. I removed the electrical connector from the unit completely (the other end connects to the adjacent board with the fuse on it) and cleaned the connector plug with electrical cleaner and re-inserted it into the receiver and built everything back up. I am happy to report that the tv starts up first time every time and has not turned itself off since. I have included a picture of the offending plug in its built up state (it is the one with the row of black wires with one red wire). Do not attempt to do this unless you are suitably qualified.
Jun 09, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Tv keeps turning off getting code E01
Don't waste time,call 1-800-pioneer!
Best time would be T-Thursday at 7amPST.
Good Luck!
Jun 02, 2008 | Pioneer PureVision PDP-4340HD 43 in....
PDP 5030
This may help you Greger, I found this on another site and I assume your model is simular to the 503 HDE... Good Luck - Rob...
I had exactly the same problem with my 503HDE. Screen would randomly shutdown and display E01.
In my case I believe that the cable was not at fault. The power supply in the media box looks like the most likely culprit.
I dismantled the media box and removed the LARGE power supply board and checked for dry solder joints. Sure enough, where the heatsink was soldered onto the board the joints were in a bad way. I reckon this is a symptom of the fact that the media boxes for V3 Pio's get very hot - all that expanding and contracting is likely to create dry solder joints. Taking the box apart shouldn't be a problem for anyone with a reasonable level of IT type skills!
I resoldered the joints and (touch wood) I've not had a problem for over 2 months. Whilst I can't guarantee that this is the definitive fix for this problem it seems to have worked for me. I'd be interested to hear if anyone else finds this cures the E01 problem.
Not being a hardware engineer, my only doubt is why the heatsink is connected electrically to the circuit board. Would this be for earthing purposes or perhaps to do with temperature sensing? Not sure about that - rolleyes.gif
Hope this helps someone - six grand is a lot of dosh to write off!! __________________
Dec 26, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer PureVision PDP-4330HD 43 in. HD-Ready Plasma Television Logo
334 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
