Question about Nokia N70 Cellular Phone
Problem with memory card
I did format my memory card from my cell phone itself, but it is not working. Is it possible to format my cellphone. Thx
Remove your memory card and put on the memory card reader,
insert the usb port of the system.
after open my computer right click the memory card drive select format option, then open the dialog box select fat file system and quick format ok finaly ready your card
Posted on Jan 29, 2009
After decryting my memory card i cannot format my memory card
where did you encrypt your memory card?...if its on pc then insert in pc if its on cellphone then use it on cellphone...format it where you decrypted it.
Apr 05, 2014 | Nokia N72 Cellular Phone
Tip
How to Transfer Files from Cellphone to Laptop and Vice Versa
<span>There are three ways that you can use enable for you to transfer files from your cellphone to your laptop or vice versa.<br /><br /><span style="font-weight: bold;">1. </span> <span style="font-weight: bold;">By using a connectivity cable</span>. <br /><br />It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.<br /><br />A connectivity cable looks like this.<br /><br /><img src="carloadrian_2.jpg" /><br /><span style="font-weight: bold;">2. Bluetooth</span>. <br /><br />Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth. <br /><br /><a href="/../support/t8013435-connect_laptop">CLICK HERE</a><br /><br /><br /><span style="font-weight: bold;">3. Memory Card<br /><br /></span><img src="carloadrian_4.jpg" /><br /> <a><br /></a> <span style="font-style: italic;">SD cards are used in many cell phones</span>.<br /><br /> Many cell phones come with removable memory chips, which can be used to expand the available storage on the cell phone, or to transfer files (such as music and pictures) between the cell phone and other devices. Once you identify the kind of expandable memory in use on your phone, an adapter can usually allow you to connect it to a laptop as if it were a USB drive. <br /><br /><span style="text-decoration: underline;">INSTRUCTIONS</span><br /><br />1. Determine what kind of two-gigabyte memory chip your cell phone uses. You can do this by checking the specifications of your cell phone in the manual or on the manufacturer's website, or by removing the card and examining it. As of April 2010, the most common kind of memory card used in cell phones is the SD format, which comes in standard, mini, and micro sizes. Your phone may also use the Memory Stick Pro or Pro Mini format. The format type will be printed on the side of the card. <br /><br /> 2. Purchase a USB adapter for the card you are using, which is available from many different vendors. If your card is in a mini or micro format, make sure that the adapter comes with a sleeve for the card of your size; this allows you to insert a mini or micro card into the sleeve, and changes the card into a standard size for use with the adapter. <br /><br /> 3. Insert the card into the sleeve, if necessary, then into the adapter. Connect the adapter to a USB port on your laptop. The card will appear on your laptop as if it were a USB drive. When you are finished working with the card on your laptop, you can move it back to your cell phone.<br /><br /><br /> </span>
on Jan 28, 2011 | Cell Phones
How to remove virus from phone memory
Have a blessed day. My name is dingra. There are a few things you can do to attempt to remove the virus from a cellphone.
1.Format the memory card in your cell phone. It may actually be the memory card, not the phone itself, that is infected with the undeletable virus. On most phones, you can format the memory card directly from the phone by going to the "Options," "Settings" or "Tools" portion of the main menu screen on your cell phone. Consult the manual that came with your phone to learn exactly how to format the memory card in your cell phone. You can also find these user manuals directly on the manufacturer's website.
2.Buy a new memory card for your cell phone. The undeletable virus may have damaged your memory card beyond repair. If formatting the memory card didn't fix the problem, getting a brand new memory card may fix your problem. These memory cards are relatively inexpensive and can be purchased at just about any store that sells cell phones.
3.Format your entire cell phone. If getting a brand new memory card hasn't fixed your phone, formatting your cell phone should remove the virus and every other file on the phone. Before you attempt to format your cell phone, remove your memory card. Read the manual for your specific cell phone, as the instructions for formatting cell phones vary based upon the manufacturer of the phone. fir
Hope it helps.
Thank you for using fixya.
Oct 01, 2011 | Cell Phones
Nokia 7210c memory card was not working
hi,try to my advice you get out your memory card from your cellphone,and try to reformat your cellphone and memory card.but before you reformat your cellphone,you need to back up or save your contacts to sim memory.after that you reformat your cellphone,you reformat also your memory card to computer,i aware you if you reformat your memory card all data or files you save is delete all.nokia reformat manual just dial
Jul 29, 2011 | Cell Phones
My memory card was functioning well but then when i was playing a game in my cellphone, it said, operation failed. Then after that it said that "Memory card not inserted" though my memory card is...
first: TRY TO INSERT YOUR MEMORY CARD TO ANOTHER PHONE THAT COULD SUPPORT IT...IF IT WORKS ..THEN THE PROBLEM IS YOUR PHONE..MAYBE YOUR MEMORY CARD IS TOO MUCH FOR IT..
2ND IF YOU INSERT TO ANOTHER PHONE THAT SUPPOSEDLY SUPPORT IT..AND IT DOESN'T WORK..THEN THE PROBLEM IS YOUR MEMORY CARD..
fyi: REFORMATTING YOUR MEMORY CARD COULD CAUSE SEVERE DAMAGE TO YOUR MEMORY CARD..IF YOU HAVE HAD FORMATTED IT AGAIN AND AGAIN, THEN EXPECT IT TOO FCKED UP... IF YOU WANNA DELETE FILES IN YOUR MEMORY CARD JUST OPEN FILES AND DELETE THE,..DO NOT FORMAT YOUR MEMORY CARD
Mar 06, 2011 | Cell Phones
My nokia 7210supernova is in trouble,my music player and calculator is not working.it shows not enough memory.i tried 2 format my memorycard nd me cellphone but its still shows not enough memory...w8ng for...
It is possible that some error has crept into your software and corrupted. It is possible that some downloaded files- in your memory card has made this happen. So remove the card and have it scanned in your PC. remove or format the card, replace battery and restart phone , if the software does not reset then it might need a re-installation. Have this done at the Nokia care.
Jan 18, 2011 | Cell Phones
Gud am sir, i have a problem with my cellphones model nokia 3110c, i cannot used my music player, every time i open it, always appear no music files found, even i had to much song files in my memory...
First Solution:
Try bluetooth, ask your friend(s) to send you song via bluetooth then save it to your phone memory or memory card, if it is working meaning there is no problem with your cellphone. It's in the audio format!
Second Solution:
Backup all of your songs then copy one(1) song and convert it using audio and video converter into mp3 format. Though your songs in your mp3 player are already an mp3 format. Some cellphone can not read it as mp3, after converting copy the song that you converted as mp3 format into your memory card but before that format your memory card first. Good day
Nov 30, 2010 | Cell Phones
Help with memory card inkrazr cellphone
Do not use card reader and format with pc, you only format the card with the phone,and only once.
If you format the card with your pc the phone migt not see the card anymore,even if you format fat32. The card is suppose to be formatted with phone because the phone needs to build folders in the card.
As for saving anything,say pic,just open options and choose card.
Apr 13, 2009 | Motorola Mobility RAZR V3x Cellular Phone
How to format n72 cellphone not memory card only cellphone
you make swich off ur phone .in off condition press simentinously green (dial button),*,3and on ur phone (4 keys 3+on/of=4)your display shows formatting (in hands only)
Mar 13, 2008 | Nokia N70 Cellular Phone
Denied access to MMC to motorola cell via usb
Try to reformat the memory card with a Laptop or PC then try put it in. Or use the formatting tools on that phone to format the memory.
Aug 04, 2007 | Motorola Mobility E398 Cellular Phone
Nokia N70 Cellular Phone Logo
62 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
