Question about Sharp AR-168D Black and White Copier
Sharp Copier AR-168D is not working. Code displayed is U2-40.
Sharp Copier AR-168D is displaying U2-40 Code. This code is not in the book. Can you advise how to fix?
  • nthabitcpa Jan 29, 2009
    Yes, it corrected the problem. It would have been great if this was in the book, but I am pleased anyway. Thanks
    Sergeant:
  • 320 Answers
Please go through the manual once for resetting the device.. to see the manual, click on the below link,,,
http://www.sharpusa.com/files/cop_man_AR168S_AR168D.pdf
You need a new fusing unit.visit this site for the codes:
http://www.visualhawk.vcc.ro/sharp_error... there accoeding to your matching code, you can replace that part. For more information about troubleshooting the device, please click on the below link.. http://olsonbros.com/sharp/support/sim_pdf/sim-ar168s.pdf Thank you....
Posted on Jan 29, 2009
  • 11,896 Answers
Clear key Interupt Key Zero Key Interupt Key 16 Print
did you get a new toner cartridge?
here is a link to your manual
http://www.retrevo.com/d/ds/progress?doc=56e90305a2827b75168401d41a58272e
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    http://www.retrevo.com/search/v2/jsp/myt...
  • Nate Stansfield
    also check for Broken front door hinge
  • Nate Stansfield
    after studying your manual, it has turned out that your correct code U2-40 actauly means
    CROM. communication error
  • Nate Stansfield
    Replace system board
  • Nate Stansfield
    http://www.best-price.com/productsearch/...
    A link to your part. The crom chip on the toner needs to be replace or try to be reinserted
    or
    http://www.precisionroller.com/manufactu...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding error code U2-40 on most Sharp copiers indicate a board problem (hardware). You could try performing a reset to verify. If the reset corrects, then it was a glitch; if not then it may be to your advantage to seek the services of qualified professionals. To reset, try:
  • press on #, interrupt, clear, interrupt;
  • screen display "service Mode;
  • enter 16;
  • print;
  • are you sure?
  • yes.
Post back updates. Good luck and thank you for using FixYa.
    Genius:
  • 1,550 Answers
The error code means CRUM communication error.
The CRUM is a chip that resides on the toner cartridge that keeps track of the toner usage and resets when a new toner is installed. If you replaced the toner recently it may be corrupt.
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Aug 03, 2010 | Sharp AR-168D Copier
Hi, Can someone help with resetting error H2-00 on sharp 168d
H2 00
[Content]
Thermistor open
[Detail]
The thermistor is open.
The fusing unit is not installed.
Cause Thermistor abnormality
Control PWB abnormality
Fusing section connector disconnection
[Check and remedy]
Check the harness and the connector between
the thermistor and the PWB.
Use TC 14 to clear the self diagnostic display.
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
Enter 14 Start to clear the code.
Oct 26, 2009 | Sharp AR-168D Black and White Copier
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-168D Black and White Copier Logo
377 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
