Question about Maytag Neptune MDG5500AW Gas Dryer
When I push the start button on my maytag neptune dryer it sounds
Like it wants to start but doesn't and then it gets this smell like something is burning? When it does start which is getting less and less it takes a while before it kicks in and gets the barrel moving.?. Please help!!
I have a neptune dryer gas,electric mdg3000axw do not know how to hook gas up and what kind
Posted on Jan 30, 2009
  • 65 Answers
MORE TIMES THAN NOT, WHEN I HAVE SEEN THIS PROBLEM, IT TAKES A NEW MOTOR TO CORRECT THIS SITUATION. MAKE SURE EVERYTHING MOVES FREELY BEFORE CONDEMNING THE MOTOR THOUGH.
Posted on Jan 29, 2009
Maytag Neptune MDE3000AYW. The start button on my dryer went out. It tried to start and then died and smelled burnt. I am guessing the switch burned up. Any thoughts on how to fix it? Thanks
sounds like motor is in a bind see if you can rotate drum by hand if you cant then your belt is hung up,or a belt pully is bad,if drum turns freely,sound like motor is going bad
Jan 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Hi. My Neptune dryer was not sounding as I remembered it. A higher pitch than usual while it was drying clothes. Then I noticed it was reluctant to start when pushing the "start" button, with...
burning smell is because the drum is not rolling and the motor is trying to turn, hopefully it did not damage the motor: more then likely it the drum rollers/glides, might want to check the idler arm here is a website that will help. depending on fast you need your dryer a good and cheap place to buy parts is on eBay, of course they can be purchased locally, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 10, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer lags when pushing start button. Sounds like it wants to start but won't. Also, there was an aweful smell with it that filled the house. It is a Maytag Neptune
sounds like you cooked the motor,did it smell like shellac,if it did it's the motor,see if you can spin the drum by hand,if it feels bound up the belt or something could of got jammed in the blower wheel killing the motor,or it could have overheated from not cleaning out the dryer.the only way to tell is by getting in there and checking it out,let me know what you find,unplug the dryer,open the door,remove the two screws holding the door in place and then remove the door.next remove the other two screws opposite the door screws and pull the front panel off.remove the bulkhead and L brackets on the top and pull the drum and belt.you'll need the model number and the first two numbers from the serial number to order your parts
Apr 21, 2010 | Maytag Dryers
Burning smell, Loud noise when start button and doesn't turn on
Belt, and skid plates very easy to change and not much money
Aug 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
The start windings in your motor have gone out. You have to replace the motor to fix this problem.
Jan 29, 2009 | Maytag Dryers
Maytag electric
Yes, I would replace the starter switch...Also, there is a relay next to the starter switch(behind panel) that may be on the blink.. Try switch first as they are cheap.. The Repay retails for around $50.00. Goodluck!
Dec 15, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
211 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
