Question about Acer AL1912 19" LCD Monitor
I have a acer al1912 faulty
Hi all, I have an acer al1912 monitor faulty, can i use the boards from a acer al1712 to replace it??
  • Acer Master
  • 5,568 Answers
It might be worth a try but the two different sizes could have differing resolutions and if they do, the boards are not likely interchangeable.
Posted on May 12, 2009
Al1912 monitor with grey volume box stuck on screen....can't buy new circuit board and all silver buttons don't work at all ....reg y
Normally problem is defective switches rather then mainboard. If volume + is coming on chances are that the switch is mechanically stuck or electrically leaky. If you are technically able I can guide you further. Regards. Samir
Feb 07, 2011 | Acer AL1912 19" LCD Monitor
I have a AL1912 B monitor that won't turn on. The green light in front just keeps blinking.
Power board problem, in all probability capacitor failure. Needs the capacitors checking and replacing, but will probably be cheaper to get another monitor
Jan 12, 2011 | Acer Computers & Internet
Hi there,my acer al1912 monitor lights up briefly after i turn it ln and then turn black what could this be? Pieter
It could be the problem in the power supply because of bad caps, or bad inverter circuits, or worst will be bad lamps. Look for bad caps first and report back what you see so we can guide you further, see example of failed monitors due to bad caps and lamps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | Acer AL1912 19" LCD Monitor
How can I connect my Fujitsu Siemens key board with my Acer AL1912 monitor? There is a connect button on the key board, but where is the connect button on the Acer?
Is it a wireless keyboard? If that is the case, then you should have a receiver unit attached to the PC, usually to a USB port. The ACER is justt a monitor, here is the user manual: http://www.retrevo.com/support/Acer-AL1912-Monitors-manual/id/719ag115/t/2/
Jan 20, 2010 | Acer AL1912 19" LCD Monitor
My acer AL1912 monitor keeps going fuzzy. It kind
An unusual problem for a flat screen monitor.
I suggest you connect the monitor to another PC to see if the problem persists since it could also be caused by the video card (or circuit, if on board).
Check your cables making sure they are solidly connected and wiggle them to see if you can cause the problem to come or go away; this would crudely check the shielding of them.
This kind of aberration could easily happen with a conventional CRT monitor if power supply filtering was failing but as mentioned, uncommon in a monitor that is essentially digital.
May 12, 2009 | Acer AL1912 19" LCD Monitor
Acer AL1912 -- missing capacitors & parts list
I don't normally respond to any questions on here anymore so forgive the delays in response.
The missing capacitiors are due to the board being made for a series of monitors using different power settings and having other things added to the mix like sound amplifiers etc (yes they live on the power board) so not all component holes will be filled unless the board is from a fully optioned model.
The fault you will be looking at can vary depending on the board manufacturer. If you can email a photo of both sides of the power board I will highlight the areas you will need to check.
mailto:saitek@tpg.com.au
Aug 06, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 with S3inc trio 32/64 card
start with a 1024x788 60hz refresh , connect lcd
and then try any higher freq/refresh as it will ask you to verify.
Nov 02, 2007 | Acer AL1912 19" LCD Monitor
Acer AL1912 Monitor Looping
I have fixed many of the al1912 easy fix
the problem is always corrosion on the circuit board that has the buttons
disassemble the flat panel remove 3 screws that hold button board on
disconnect the tiny cable from the button board
use a tooth pick and clean inbetween the solder connections where the ribbin cable plugs into button board
Apr 10, 2007 | Acer AL1912 19" LCD Monitor
Acer AL1912 19" LCD Monitor Logo
245 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
