Question about Motorola Mobility RAZR V3c Cellular Phone
Razr Phones Memory
Everytime i check the memory of my razr phone it keeps getting lower and lower and wont let me add anymore pictures or ringtones
  • deefam1 Nov 22, 2008
    I have the same problem - resetting motorola vc3.  But I don't know my security code.  Any thoughts?
  • Anonymous Mar 25, 2014
    Only the standard phone ringtone works
  • 28 Answers
You can do a master reset but this will erase all your personal information. The master reset is found by searching through the Menu.
Posted on Aug 01, 2007
SOURCE:
I HAVE A MOTOROLA RAZR- NOT SURE WHICH ONE-THE MEMORY LOW MESSAGE COMING UP. DONT KNOW HOW TO DELETE TEXT MESSAGES. HELP!
To delete text messages you go into your indox under "messages", highlight the message you would like to delete, press the menu key and select delete.
Your "memory low" message keeps coming up because your memory not only holds your messages but EVERYTHING else as well.....pics, games, ringtones, etc. Try getting rid of things you don't need to gain more space. You might want to look into getting a SD card if your phone is capable. Hope this helps you. :)
Kim
__________________
Oct 30, 2010 | Motorola Mobility RAZR V3c Cellular Phone
Will only hold 8 messages then says memory full delete messages
hi, this is a very common problem you need to delete any inbox/ outbox/ saved messages/ sent messages/drafts delete all the messages you can and dont need to keep.
You can also free up loads of memory by deleting all the ringtones you dont use as most people never use the ringtones you get free with the phone so delete all these that your never going to use as this will free up loads of extra memory.
You can also delete and pictures on the phone that you dont want as these also take up loads of memory but the biggest use of memory is ringtones so deleting all of these will free up loads of memory allowing you to recieve hundreds of messages.
Let me know how you get on or if you need further assistance ok
Dec 29, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Downloading a ringtone to my phone
in motorola v3 razr ringtones get downloaded in the phone memory and doesnot go to the card memory . so you need to switch the memory to the phone memory and then you will be able to see that ringtone. once you move that ringtone to the card memory and then you can assign the ringtone also .
If you want ot assign the ringtone to some particular contact then it should be in the phone memory then only it wil pick up that not from the card .
Mar 26, 2009 | Motorola Mobility RAZR V3
Storing text messages
This is because the Razr stores texts and emails dynamically according to message size and physical memory available. To balance it out, you would have to delete some outbox messages to store more inbox messages and vice versa. The amount of pictures, ringtones, incoming/outgoing calls, emails, texts, and videos all are drawn off the physical memory of the Razr. The device does not have dedicated application memory so everything is taken off the small amount of memory you are given. Newer Razr's such as the V3m for Sprint offer Memory Cards to supplement additional memory. Your device is equipped with a microSD card slot and you can save your music, pictures, and videos to the card and leave the additional phone memory to texts and application memory. You may not be able to save that much more if you move the pictures and music, but you can save more than if you didnt have a memory card. When reaching the maximum limit of memory the phone will tell you that you need to delete some files before continuing to do anything on the phone.
Dec 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Storage Space
The Original Razr V3 does not have memory card abilities, so you would need to delete any pictures, ringtones, and apps that you no longer want.
The newer versions such as the V3t can use MicroSD cards.
Nov 26, 2008 | Motorola Mobility RAZR V3
My Phone is VERY full
Have you tried erasing old pix and text messages? If you check your phones available memory, and you have a lot of pix etc you can get a micro sd card and move your pix and videos to it. You check memory by going into menu, then se1ttings/tools, then phone info , other information usually...Good Luck
Sep 03, 2008 | Motorola Mobility RAZR V3
How to download ringtones to my cellphone
ur phone is supported by mp3 formats, use a card reader and connect it to your pc, then put all the songs u like into ur external memory of your phone
Aug 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Taking a picture
Choose the photos to move ro memory card and change the phone settings to send the photos to phone memory..
May 11, 2008 | Motorola Mobility RAZR V3
How do i access my memory card
If you are in your pictures or ringtones and you want to get to your memory card, go to options and switch storage device to Trans-T-Flash. If you are wanting to check the memory on your card, go to Settings, Phone status, Storage Devices and it will show the memory on your card and on your phone.
Sep 02, 2007 | Motorola Mobility RAZR V3m Cellular Phone
How can i change my ringstyles?
After opening the lists of ringtones press middle key on phone then switch to card memory to phone memory. Then only you can change your ring styles.
Jul 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
344 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
