Hello, We want to set up acer through firefox to att DSL 2701hg-b Gateway. Please provide directions to access area to put in key code and password to create set up. Thanks. Gloria
  • Kevin Nelson May 11, 2010
    1. go to the box it came in.
    2. remove the instruction book
    3. check first few pages for "getting started..." or "setting up..."
    4. if no book is there contact ATT and they will provide one
  • 201 Answers
Try this:
Posted on Feb 17, 2009
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
I need to find my att dsl internet security key to sign on wireless my moden is a 2wire 2701hg
Open INTERNET EXPLORER and. (In the URL address field), enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "" as the address. This is usually the default IP address for most not type "www" just the number
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for passsword.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.aka security key
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Feb 04, 2011 | AT&T High Speed DSL Modem
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
2wire 2701HG-B gateway can't connect locally
Have you got MS CLient loaded in the network settings. If not run network wizward on each machine and then try again. hope this helps Mark
Aug 18, 2009 | Computers & Internet
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Att2wire 2701hg-b to replace peoplepc dsl Zyxelp-600 series modem
do you also have AT&T? att2wire 2701hg-b gateway is configured to work with AT&T only that's why if you have a different ISP, it will not work for you. Most ISPs provide modems that are configured solely for their service.
Apr 26, 2009 | 2wire 2700HG-B Router (2700HGB)
Att 2701 hg-b modem
Hi , the 2701HG-B by default uses the last 3digits of the SN number as the SSID and the 10 digit number in brackets as the WEP key to access the user interface of the 2701 type in the address bar of your browser and push enter, to access the interface program you will need to run the system set up and you must know the keycode from your service provider and the username and password
Jan 06, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I need to find the procedure for at&t 2wire DSL modem wireless connection. I lost the security code and password. The Serial N# is 140811022206 and another # is (2701HG-B) could be the model number. ...
Try going to your support site or try calling your Internet provided and asked them to create a new username and password for your wireless connection.
If your asking for the username and password that you set in the modem configuration page more likely you are going to reset it and call your Internet service provider for the default username and password for your 2wire modem configuration page.
Jan 04, 2009 | Sprint PCS Merlin S720 Mobile Broadband...
2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 07, 2008 | 2wire (1000-000057-000) Modem
I have a 2wire 2701HG-B try that, it should work
Dec 19, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
