Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Bad smell inside washing machine
There is a terrible smell coming from inside the washing machine. It has existed for at least six months, and continues to get worse. I would compare it to the smell of raw sewage. We have tried running a gallon of vinegar through it a number of times. It used to help, but now that doesn't even dull the smell. The smell exists 24/7 and is not tied to the use of the machine.
    Novelist:
  • 159 Answers
Im sure the smell you are getting is from the detergent. The best way to solve this problem is to take the cabinet off the washer and then remove the white trim ring on top of the wash tub and scrape all the rotting soap buildup from the unit. It may sound harder then it seems but it is a easy job to do. Im guessing here but I would say you use liquid detergent. If you do you may want to try using a power like tide because the powder will not suds up as much a the liquid soaps do. Good luck
Posted on Jul 26, 2007
  • 51 Answers
I have found that the best solution to clearing smells for your style of machine is to fill unit with hot water wash & put in 3/4 to 1 cup of baking soda. You should repeat this 2 times. I am assuming that the underneath & behind machine have been checked and that the smell is from the machine internally & not externally. Good luck! Regards
SOURCE:
Every time we try to use our gas fireplace the smell of gas is terrible. Why?
Turn it off at once do not use and phone the a gas company to come out and look at this asap
Jan 17, 2018 | Heating & Cooling
Why does my Whirlpool Cabrio HE Washing Machine smells like urines and how can I fix it?
try using some baking soda water in it ,that works for smells sometimes better than bleach
Oct 25, 2015 | Whirlpool Washing Machines
Smells like something dead inside 2009 mountaineer. Worse when ac is turned on. Have removed everything from car and vaccumed. Just started suddenly. We live in country and suspicious for mouse,...
o god, try looking at cabin box filter. The only thing really is to remove the dash and all heater tubes and vents. I hope its easeir than this for you though. I have a transport that mice got into the heater system and i had to strip the inside entirely except for electrical. Mind you the van had sat for about a month with a blown engine, but it took around six to eight months to rid the smell as they of course did their #s in everything let alone the smell of death. you have to find it or it gets worse. best of luck to you. Anything you remove dont forget to wash it with soap and water.
Apr 04, 2011 | Mercury Mountaineer Cars & Trucks
My Rancilio Silvia developed a terrible burning smell. The water still comes out of the steaming wand. I have only been using the steaming wand for the last month and not the espresso maker. I have been...
Sounds like the machine needs to be descaled and the boiler and element needs to be checked.
Was the machine left on for a long time?
If yes then the element needs to be replaced.
Feb 20, 2010 | Rancilio Silvia Espresso Machine
Smelly top loader. It stinks. The clothes don't smell, though. The smell is coming from between the porcelain bowl and the metal exterior. It realy smells terrible. I've run 2 loads of hot water with...
Bacteriological action is becoming more of a problem nowadays due to low temperature washing , the deteregents , wash your clothes well but do not kill off bacteria , this is generally harmless to us but can build up in your machine , giving rise to a smell and sometimes a slime which can get on your washing. A regime of High temperature washes WITH NO CLOTHES IN MACHINE , just a dose of bio-powder every six to eight weeks , may help.
Nov 08, 2009 | Washing Machines
HE4t washer leaves clothes smelling worse than when they went in. They come out smelling like clothes that have been sitting around for months. I suspect the cycle sequence is just draining the soap, but...
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Aug 29, 2009 | Kenmore Elite 45986 Front Load Washer
Terrible smell coming from washer while in rinse mode.
This is classic bad design actually.
Some washers are worse than others for this.
Use an oxygen based bleach in a trigger spray, and remove the detergent drawer. Use the spray everywhere in there - and remove the drawer completely to wash it in a mild bleach solution.
Use a small brush to remove the mould in there - and flush it down the pipe with more spray.
If you an get a foaming cleanser down there - then even better - or an alcohol based sanitiser spray.
Also wipe over the door seal rubber - as this sometimes collects stagnant water in the folds.
Reassemble, and do a hot wash with a few white hand towels to remove all the bleach.
You may need to do this every month.
Doing hot washes helps - maybe with a cap of bleach.
(I think the manufacturers do this on purpose - so you wash more often - breaks machines - you buy a new one etc.)
Aug 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machine has burnt rubber smell
your problem is probably the coupling that ataches the motor to the transmission , take the skirt of the washer off , take the motor off and you going to see the rubber coupling if is bad just change it , cheap part
Jun 18, 2009 | Amana LW8203
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
162 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
