Question about HP Pavilion vp15 Monitor
We have a HP vp15 monitor. Recently we have not had any sound.
The monitor sound menu indicates 0 and we do not know how to raise that number up so that we can have sound?
Thank You very much,
Larry Michalowski
  • 34 Answers
Monitor control buttons are located on the front panel of the monitor on the lower right. Make sure that you connect the built-in monitor speakers to the computer, using the audio cable (green connector). The connection on the monitor is located on the back of the monitor. On that monitor I believe the volume button is the second one (from left tot right) on the lower right. Also you may want to check your systems volume on your computer by left clicking one time on the little speaker on the lower right of your screen by the clock.
Hope this helps
Rate It!
Posted on Jan 29, 2009
I recently hooked up a HP f2105 monitor to a Mac G4 tower running Leopard OSX. The monitor works but when I try press the menu button the menu shows on the screen but neither my mouse or keyboard can...
You can call us 1 (888) 687-4491 HP Support Number for any of the issues like HP computer OS problem, software issues, driver issues, virus related issues, connectivity error, printer connection and scanner issues. We will solve your technical problem without any delay to deliver a reliable online help service at low cost.
Dec 20, 2017 | HP f2105 21" LCD Monitor
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
Sounds like one of the buttons on the monitor is sticking physically. Try:
  • checking the buttons for dirt that might be holding it in
  • cleaning the buttons with a soft brush
Apr 15, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
dirty switch. I took my 2009m apart and cleaned the switches with alcohol on a qtip and the problem's gone. Not too hard to do. Leverage the case gently with a putty knife or something and it will pop open. Then pop around the edge to remove the back completely.
Dec 23, 2009 | HP 22" Widescreen Flat Panel TFT LCD HD...
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
How can i open the body or case to repair of hp vp15 lcd monitor
well being as how i just did this five minutes ago I can help:) The back of the monitor has a thin panel like a sideways 8 or a bean shape...this pops off then you have to take out the screws holding on the base once you get that off you can lay the monitor flat <carefully> and pop the outer black frame off <every so often along the seam you will see little gaps stick a thin flathead in if it's to tight for you carefully not to scratch or break it is plastic!> then you will see the metal case and find the screws on the sides and your there! Good luck!
May 18, 2009 | HP f2105 21" LCD Monitor
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the circuit board parts / connections if loose/broken/defective. regards
May 17, 2009 | HP f2105 21" LCD Monitor
My lcd hp vp15 monitor cannot power on,when i push power swich it then power swich flashing but screen does not anything screen is black.please help me
Its a problem with the monitors power supply ,you will have to take it to an HP support center and ask for a quote.
if it's under warranty then you won't pay to fix it.
May 06, 2009 | HP f2105 21" LCD Monitor
Hi, did you solve your Samsung SyncMaster 910MP problem? I have the same problem, I can't see TV but I hear the audio; do you know if it's only a setting problem or i have to bring the monitor in a service...
I had what you describe here, I could hear audio, see the menu, all was there but no picture. Then I found out that my 910MP had done a spontaneous reset of the Contrast/ Brightness/ Color/ Sharpness to 0/0/0/0 by itself. I have raised the settings again and the video is back.
May 13, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Open Questions:
See all HP Pavilion vp15 Monitor Questions
HP Pavilion vp15 Monitor Logo
161 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
