Question about LG 42LC2D 42 in. LCD HDTV
LG flat screen TV speakers make a vibrating noise
46 inch LG HD flat screen TV the speakers seem to have a slight vibration that distorts the voices. It does not occur with every word but often enough to be a pain.
  • 6 more comments
  • chagopian Feb 15, 2009
    same problem, 37 inch LG flatscreen.
  • Anonymous Feb 22, 2009
    Same problem and LG customer helpdesk have no solution.... AVOID BUYING ANY LG TELEVISIONS!!!!!!!!!
  • flourite_100 Feb 22, 2009
    Lower tones seem to cause a vibration noise. I am guessing something loose hold speakers or the speaker is broken
  • ui73 Mar 01, 2009
    I have the same problem with the LG 37 inch. It is more noticeable in Cinema sound mode.
  • drascal Mar 18, 2009
    I have the same problem with my 42" LG model 42LB4. I just took the back panel off to check speakers and they appear to be fine. I thought they might be blown. I'm going nuts trying to find something that could vibrate. It starts at only about 30% of the 100% volume.
    Can anybody help? I don't want to buy new speakers only to have NOT fixed the problem.
  • NickGSD Apr 02, 2009
    Yes, I have the same problem too with my 32 in. I assumed when I first heard it on higher register that it was the plastic casing, so I put a pad under the base, but no change. I squeezed the upper right back of the console, thinking that it would tighten up the vibrating plastic, but still no remedy. I wondered how the problem coud be a blown speaker since I never shot the volume higher than 60, so I tried fiddling with the woofer-tweeter adjustments, seeking a new balance. No luck. I'm sure it's a lack of pads or felt gaskets between the speakers and the plastic case, but I'm not about to open the console. Perhaps the problem can be solved only by attaching separate speakers.
    Nick G., San Diego
  • Anonymous Apr 11, 2009
    anyone has a resolution to this problem? I have 2 of these in my home..
  • amieeshipley
    amieeshipley Dec 09, 2012
    Same with the 55 inch flat screen....
  • 4 Answers
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Posted on Apr 16, 2009
  • Armando Garcia
    Armando Garcia Sep 07, 2013
    LG IS A FUKIN RIP OFF HATE THEM MUTHAFUKING COCKSUKING PARASITES
  • 14 Answers
How to stop LG tv speakers vibrating?
It's not as simple as it sounds is it because the cabinet is supposed to resonate by design. I have a workaround which works for my setLG flat screen TV speakers make a vibrating noise - luxhello.gif
If you think about it, the Cinema default EQ setting already increases Bass at default from flat.
Then if you consider SRS Trusurround also adds Bass too therefore You're already going to give the tiny tv speakers a good going over even at relatively low volumes.
Couple that with Freesat (which on my set is louder than all the other inputs) and then throw in BBC HD which has decent audio and it's probably no wonder it's crying at me with this vibration/buzzing.
So what I've done is tweaked the Cinema setting as follows:
SRS Trusurround : on (widens the soundstage nicely with these below on mine).
Auto volume: off
80hz = (0)
220hz = (-1)
470hz = (0)
1khz = -(1)
2.2khz= (1)
4.7khz(1)
12khz= (1)
I appreciate different room sizes/environments etc, but I honestly have it at 40 volume for the first time with no distortion. It's also giving me decent levels of bass and treble after trying in addition to BBC HD, Clubland tv, FIVE to give me the broadest samples of broadcast content/sound levels.
Posted on Jun 08, 2010
  • chrisbalmer Jun 26, 2010
    Jun 26, 2010 - by chrisbalmer
    - update to my previous post. I added "acoustifeet" (I chose the firm variety- link at end of post) to the rear of the bezel and to the base and eliminated all buzzing. I also have enhanced EQ settings as follows:
    80hz = (-1)
    220hz = (0)
    470hz = (+3)
    1khz = (+5)
    2.2khz= (-3)
    4.7khz =(+3)
    12khz= (+5)
    http://www.quietpc.com/gb-en-gbp/product...
  • chrisbalmer Jun 30, 2010
    final updated settings:
    80hz = (-5)
    220hz = (-4)
    470hz = (-5)
    1khz = -(-6)
    2.2khz= (-4)
    4.7khz=(-2)
    12khz= (0)
    Champion:
  • 211 Answers
You can try to connect a headphone and listening if you hear the same distortion.
If not, there could me a resonance in the housing of your TV or blown up speakers.
Cheers,
Gerard
Posted on Jan 29, 2009
    New Friend:
I had success using sections of a rubber band taped over the plastic pegs on the backing panel. I believe they were vibrating against the sheet metal behind the screen.
Posted on Mar 04, 2013
  • btreacy
    btreacy Mar 04, 2013
I have a wall mounted 60" lg. Same problem. Stuck a shirt and sock (per another recommendation) back there where the rear metal housing was vibrating and all is well.
Posted on Apr 28, 2009
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
Screen broken
Its not worth repairing since the cost of the screen will be about the same has a new TV
Jan 06, 2014 | LG 46LD550 46-Inch 1080p 120 Hz LCD Hdtv...
My 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.
I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
Mar 02, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
TV makes a continuous distorted vibrating kind of noise...
for sure your tv dont have any ********?he he he....check where vibtation noise from but if it comes form inside the best solution is to bring your tv to a LG repair technician .
Sep 08, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
The tv vibrates and distorts sound when at sound level 20 or more so I play it with 5.1 sound sistem
Yes it is just the way the speakers have been mounted with no padding on the casing causing the vibrations. A design flaw
Aug 06, 2009 | LG 32LG30 32 in. LCD HDTV
Vibrates when shound turned up, tried different sound modes, it is the bass that is a problem deep voices etc
Rattling speakers on a LG TV is fixed by placing a small square rubber between the speakers and the chassis.
Of course the speakers will need to be replaced too
May 25, 2009 | LG 32LG30 32 in. LCD HDTV
LG 32LCD LCD TV Problem
It turn out to be a $10 diode on the mainboard, which cost me $100 to have troubleshot and repaired
Jan 19, 2009 | LG 32LC2D Television
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Distorted sound
Sounds like you have a bad speaker or where the mounts for the speaker are broke.
Dec 03, 2007 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
21,809 people viewed this question
Computer Repairing
Computer Repairing
