Question about Samsung HCN436W 43" Rear Projection Television
RED GHOSTING - tried convergence adjustment with no luck in moving the red ghost
  • Samsung Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerRED GHOSTING - tried convergence - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
MY TV IS OUT OF FOCUS ON THE ENDS CLEAR IN THE MIDDLE WITH GHOSTING RED A BLUE EVERWORD OR DIAGRAM LOOKS 3 D OR DOUBLE VISION WHY
have you tried adjusting the convergence on the tv
once they get older or get moved you need to do this
go through on screen menus and look for adjusting convergence menu and follow on screen instructions
good luck!
Mar 25, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My picture has red ghosting. I tried to perform
This set has a bad convergence amp ic. This can be a complicated repair involving in depth convergence adjustment. You may be better off having a shop check it out for you. Thanks for using fixya.
Dec 12, 2009 | Philips 55PP9401 55" Rear Projection...
Red and blue ghosting,
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
I'art color problems
Try using the convergence manualy and adjust each box. Manualy adjust red inside tv,or new bulb.
Apr 08, 2008 | JVC AV-56WP74 56" Rear Projection...
Red convergence will not adjust.
Replace STK393-570 convergence amp IC = common repair
for qualified Mits tech............................T.
Nov 09, 2007 | Mitsubishi WT-42413 42" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
Misaligned Convergence
Is anenvolved job to repair a convergence problem,the way to go about it is to locate the convergence amplifier IC's,one for each color(red green,blue)check for loose conections at the ic's legs,after resoldering all the legs see if an improvement is present if it gets better you will be able to adjust from the custumer controls,but if no improvement the Ic's will have to be replaced.Some units have a separete board were you can adjust convergence after replacing the Ic's and other units you have to access the service menu to be able to do the adjustments but just doing this adjustments can be very challeging even for a train technician,I would suggest you seek assistance from a servicer and get an estimate.
Oct 01, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung HCN436W 43" Rear Projection Television Logo
127 people viewed this question
Henry  Thomas
Henry Thomas
