Question about Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher
Frigidaire dishwasher Rylee, the circuit breaker is fine. There is no fuse on the dishwasher according to the owners manual, the parts manual and the wiring diagram. There is no timer selector switch on this model. While I changed the control circuit board, the only other thing I can think it would be is the control panel with the buttons on it. What do you think
  • 1,498 Answers
Hi Todd,
As a rule:
  • Black Smoke = Unburnt Fuel, incomplete combustion, bad mix
  • Blue Smoke = Burning Oil
  • White Smoke = Water Vapor, Water getting where it shouldn't be.
White smoke is common in cold weather when you first start your vehicle. It's from condensation. But it should stop as the engine warms up. If it doesn't, the moisture is from another source.
A blown head gasket fits the bill. Things to look for:
  • Coolant levels low. As the coolant is burned off, you'll notice the levels are lower
  • Oil in the coolant. If oil is present in the radiator, it's coming from the engine. Another indicator of a failed head gasket. Only a confirmation though, lack of oil does not rule out the possibility.
  • Water in the oil. You recently changed the oil. It should be clear and clean. Pull the oil dipstick. Is the oil still clear and clean? Or is it milky and frothy? If so coolant is getting into the oil. Again, an indicator, not a confirmation of a blown head gasket. Lack of blue smoke says that oil contamination is unlikely. On the other hand, the oil volume has to be coming from somewhere.
The quickest, easiest and (most importantly) cheapest confirmation of this is to run a compression test on each cylinder.
The test should show high and fairly close compression (100psi or more) on all cylinders. If any of them are significantly lower, something is allowing the gasses to escape. Since valve problems are usually accompanied by horrendous noises and piston ring failures would produce blue smoke, that leaves the head gasket.
If you feel comfortable doing it yourself, testers are available at any auto parts store for under $30.00. If you don't, any shop can do it in under half an hour.
All this is to pin point the problem. Then you know what you are dealing with.
Comment me back with your findings.
Mike
Posted on Feb 01, 2009
  • Justin Case
    Justin Case Feb 01, 2009
    Sorry Todd,
    I'm using Firefox and posted on the wrong tab. Please Ignore this.
    Again, my apologies.
    Good luck on your repair.
    Mike
    Brigadier General:
  • 8,619 Answers
Hi!
The timer switch i was talking about was the selector switch/cycle selector switch. And in your case the timer is embedded in the control panel, so you need to get it replaced.
If you have found this information to be valid and useful, a "FixYa" ratings would be appreciated. That is the only reward I get for the help I offer here.
Thanks
Rylee
Posted on Jan 29, 2009
Can not locate fuse for power windows in fuse box
Interior fuse box. It is a circuit breaker, not a fuse, #28, according to your owners manual. Not only check the circuit breaker, use a test lite and check for voltage on circuit breaker circuits. Sometimes, if faulty window motor, it may cause the circuit breaker to trip. I've seen some circuit breakers that were hot to the touch. After it cools off, it may reset?
Jul 18, 2017 | Cars & Trucks
Dishwasher won't run
I can help you in getting the resolution, please give me some more details
Apr 06, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
How do you reset the pump for this dishwasher
Hello friend, that's a great question!
To perform a manual reset on your Frigidaire dishwasher you would need to disconnect power to your appliance. The best way to do that is flip the household circuit breaker for roughly about ten minutes. Hope this is helpful. -Matt
Aug 20, 2014 | Frigidaire Dishwashers
Dish washer does not drain after final cycle
1 Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher. It is amazing the problems children could accidentally cause, that are easy fixes. 2 Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dishwasher to drain. 3 Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher. 4 Attempt to declog the line. Disconnect the hose from under your sink and check to see if there are any clogs. Use a hanger or towels, remove the clog from the hose. 5 Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket. 6 Call a plumber. If the dishwasher is still not draining, the problems are a little more complex to fix. It is advisable to call plumber to make your dishwasher drain.
Dec 11, 2010 | Frigidaire Professional Series 24 in....
The dishwasher starts and initially rinses the dishes without heated water. In the next part of the cycle, the water is supposed to heat to a certain temperature.Beginning this morning, in this second part...
Hi
The issue is with the heating element of your dishwasher, it is withdrawing very large amount of power and thus, the circuit gets overloaded and circuit breaker trips. You'll need to check for any short circuits around the heater element. And, also the resistance of the heater element, it should be around 1.4K ohms to 1.8K ohms.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Dishwashers
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
May 31, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Have a whirlpool dishwasher and water standing in bottom
Hi!
Please check and make sure handle link is properly seated in door latch assembly and then check that the door switch is opening and closing properly.
Check the child lock, if it is “ON” then turn it "OFF"
Review setting of wash cycles as per the instructions given in the User/Owner manual.
Now check the circuit breaker or fuse.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 06, 2009 | Bosch SHV4803 Dishwasher
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
No power
perhaps you should check the fuse in the plug and in the breaker,if there is still no power maybe a circuit has blown in which case you should call yhe manufacturers for qualified technicians.
May 05, 2008 | Frigidaire GLD2445RFC Stainless Steel...
Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher Logo
325 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
