Question about Ruud UAMB Air Conditioner
Need wiring diagram for Ruud Model UPCA-048jas
I have lost the wiring diagram for this unit and would like a new one if possible.
    President:
  • 1,214 Answers
The wiring on these is pretty straight forward
Basically a contactor, either DPST or DPDT, depending. Input power connects here.
Compressor C terminal connects to one side. R terminal connects to the other. 1 terminal of the run capacitor connects to the terminal with the R terminal of compressor. The other side of run capacitor hooks to S terminal of compressor. One wire of condensor fan hooks with compressor R terminal, the other condensor fan lead hooks with compressor C terminal.
Only things missing from all this is a hard start kit and crankcase heater. Let me know if you want to know how to hook those up.
Posted on Jan 29, 2009
Wiring diagram RUUD UAPA-036JAZ
the condensor gets 240 volts a-c and 24 volts a-c to control contactor. pretty straight forward on this 3 ton unit. the 240 volts comes off breaker box and the 24 volts comes off thermostat and common of transformer.
Jun 10, 2014 | Ruud Heating & Cooling
What will a Ruud UAKA- 048JAS typically draw in kiloWatt hours in El Dorado Hills Ca. thank you Ken
in a/c mode ?
this is a 4 ton so I would estimate in the hottest months it might pull 1200-1600 kwh depending on settings, number of people in and out of house etc. You can go by the amps, voltage and multiply by run ours expected to get more exact.
Aug 18, 2010 | Ruud UBHC Air Conditioner
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
Could'nt find model number
The only thing I can think of is to, look for the unit wiring diagram. it should be on one of the unit panels. On the diagram there should be a basic model # bot most likely not a full series #
Nov 01, 2009 | Ruud Central System Air Conditioner
Ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Jun 26, 2008 | Heating & Cooling
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
FINDING A DIAGRAM FOR A RUUD AIR HANDLER ON LINE
I dont have axcess to a wiring diagram but i am pretty familiar i know the heater wiring is crazy on these what are you having trouble with??
Nov 24, 2007 | Ruud UBHC Air Conditioner
Ruud UAMB Air Conditioner Logo
580 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
