Question about EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit
Just put together A780GM-A MOBO With dual processor amd and used my harddrive from my old system. It comes up to cmos setup, but it won't boot to windows. It comes up with the screen that ask you if you want to start in safe mode, but won't start from any of them. It also has a low beep followed by a high pitched beep everytime it tries to boot.
  • chrismcclure Feb 05, 2009
    Thanks man, I took your advice and picked up a new hard drive and installed windows 7 trial version, worked great.
  • 68 Answers
That mean you if you put a hardisk into the mobo but you never format the disk along with the mobo you need to do so. you need to format/install win xp/vista on the hard drive so that it can work with the mobo.
So here is the point, if you have a new mobo, whenever you put hardisk on it, you must format the hardisk with win xp/vista.
Posted on Jan 29, 2009
There are several possible jumper configurations on my mobo ash1 ash2 intri cmos and obr my acer aspire desktop m3100 won't boot at all I just installed a new psu & cpu
Is Cpu installed correctly ? easy to bend pins on X2's...
using a flat screwdriver make a connection between 2 pins on PWR only, disconnect everything else exept Mobo to do this just to see if you get boot to Bios, alter jumpers as you go
Feb 26, 2013 | Acer Aspire M3100-U3401A Refurbished...
Problems with Abit NF-M2S Motherboard?
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Jan 15, 2010 | Abit NF-M2S Motherboard
Green lines in black/grey screen (only vista, xp runs normal)
It's the onboard video try removing the CMOS battery and placing it back in after serveral hours, if that doen;t work it's the onboard Video replace it with a PCI Express Video Card.
Jul 27, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Can't boot 2nd OS system from partitioned HD.
go to add and remove software, deleted the last update from Microsoft. it should put you back to dual boot. try to install the update manually one at a time. find the one that prevent you from dual boot and discard the update. you should be OK w/o ceratin updates.
Jun 04, 2009 | AMD Athlon , 750 MHz Processor
I just upgraded to a Elitegroup A780GM-A motherboard, AMD 64 X2 cpu, and 4GB RAM kit. I kept my 250GB Seagate HDD that has XP Pro on it with all my important data. The problem is all devices show ok after...
It is still trying to load the drivers for your old system board which apparently are not compatible with your new board. You need to boot from the XP CD and repair your existing Windows installation. It should redetect all components and install the proper drivers for the motherboard components.
May 30, 2009 | EliteGroup Computers & Internet
I have aproblem with my Acer Aspire 3100 Laptop
locate the cmos/bios jumper below your memory ddr2 modules (J2) you need to be sure to make contact trought this jumper pe.-with a screwdriver, put back your memory modules and turn on your laptop, this process will clear your cmos/bios memory, you will need to setup your dates.
If this will not work you will need to replace your Mobo because of a faulty, we can replace your Mobo if you are interested:
10001 buckwood ave 79925 El paso tx
contact me if you are interested
support@vcrtech.com
vcrtech@hotmail.com
www.vcrtech.com
Apr 28, 2009 | Acer Aspire 3100 Notebook
Just installed new mobo (ecs 6100sm-m) and boot up issue
from my experience, you will need to format when changing the hardware you have changed. are there files on the drive that you need? if so id recommend putting your old motherboard back in to backup the drive then rebuild and format. thats if it wasnt faulty to start off with.
hope it helps
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Cannot start the computer, no reaction
When you say you have a new hard drive do you mean you already partitioned it and formatted it? It will not boot to your hard drive until a Master Boot Record is built. You have to boot to your operating system in the CD ROM, then follow directions to load onto the HDD.
Don't forget to rate this solution.
Jan 14, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit Logo
140 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
