Question about Linksys Wireless-G WRT54G Router
Wireless network disconects when connecting xbox 360
I have a linksys wireless-g router and it disconects me from my wireless network when i connect the xbox to the back of the router with an ethernet cable anyone know why?
  • 1 more comment
  • xsteve1990x Jan 31, 2009
    the xbox is connected by a wire (ethernet cable) and the laptop is connected by wireless, if i use the xbox while someone is on the laptop the laptop looses internet and if someone uses the laptop while im on xbox live it signs out of xbox live
  • xsteve1990x Feb 01, 2009
    how can i check the range of assignable adresses?
  • xsteve1990x Feb 04, 2009
    my girlfriend set it up before i met her
    President:
  • 1,214 Answers
Are you connected to the router wired, or wireless?
Have you set your laptop to a static IP on you network, and your X-box is set to the same?
Posted on Jan 29, 2009
  • 1 more comment
  • Mark Egan Jan 31, 2009
    Do you have the range of assignable addresses in the router limited to a small number?
  • Mark Egan Feb 01, 2009
    You need to access your routers menu screens.
    Did you set the router up, or did someone else, or did you just buy it and plug it in?
  • Mark Egan Feb 04, 2009
    Hmmm. Well, we'll need to know how she set it up.
Cant connect Xbox 360 to this wireless router
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Linksys WRT160N Wireless Router
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    How to connect to xbox live with linksys router
    Just to confirm you are using a wireless connection to hook up to the router? do you have the router model number? Have you configured the correct wireless settings on the 360? Make sure that if you have a key that you have entered it correctly. http://support.xbox.com/support/en/us/xbox/xboxlive/getconnected/setupahomenetwork/stepbystep.aspx
    also you can use the xbox support site for reference, use the left side panel to look at wireless settings and other help.
    Thank you,
    Lee
    Oct 21, 2009 | Microsoft Wireless Network Adapter Xbox...
    How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
    The easiest way to connect to Xbox Live without using your pc is to buy a
    wireless network adapter for your Xbox.
    You would then go into the system settings on the Xbox and configure the settings for your wireless network.
    http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
    Xbox 360 - direct to internet - No PC.
    Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
    Network connection failed when trying to connect to xbox live
    You may want to try the following:
    Use a different ethernet cable.
    Reset the router and xbox by powering them down for at least a minute.
    Run the connection wizard under Xbox Live.
    If the test passes you should be connected to the web.
    If not you might have a problem with either the router or the xbox.
    Nov 28, 2008 | Linksys WRT300N Wireless Router
    Opening the NAT connection for Xbox 360 working through 2 routers
    1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
    2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
    3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
    Hope this helps!
    Nov 15, 2008 | Computers & Internet
    Xbox 360 live on wireless router
    In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
    Nov 09, 2008 | Microsoft Xbox 360 Console
    Xbox 360 wireless adapter connection
    Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
    The following ports must be available for Xbox Live to operate correctly:
    • UDP 88
    • UDP 3074
    • TCP 3074
    Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
    Linksys Wireless-G WRT54G Router Logo
    61 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
