Question about Refrigerators
Compressor dead on a 2 year old 42" GE Monogram
Can anyone tell me if the compresor on most refrigerators is covered
for more than one year by the manufacturer in this case GE? I was told
by my repair man that most major components are covered up to 10 years. I would appreciate your feed back on this.
Many thanks,
Michael
  • Michael-Tabi Jan 29, 2009
    Thank you so much for your time and information. This is really helpfull.
    Director Badge:
    Uploaded 100 video answers.
  • Refrigerators Master
  • 488 Answers
its a big job to replace compressor on refrigerator. The warranty should cover labor and part for 7 years.
Posted on Aug 23, 2015
    President:
  • 1,214 Answers
5 years on most refrigerators. Covers compressor only, not labor or other consumables.
Posted on Jan 29, 2009
There is a control panel reset for my GE Monogram side by side, Model # zfsb23dnss, It was "repaired" with a new board and now will not cool or freeze, HELP
There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
Jul 01, 2016 | GE Monogram Side by Side Refrigerator
Mechanical wood pecker in my Monogram Refrigerator?
HELLO!!!
HA HA HA NICE JOKE !!! HMMM TRY SWITCHING IT OFF FOR FEW HOURS AND CLEANING THE TRAY AND FREEZER!!
Dec 31, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram zisw42emd, evap fan not coming on, Units been down a week, compressor seized,installed start kit. Compressor running 2.5 amps pressures 25/105 Replaced coil thermostats, evap fan not running.
that back pressures sound high to me and the hi side sound low may have a bad compressor not pumping right should run around 0 to 5 low 125 to 150 hi hope that helps
Oct 06, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram refrigerator does not cool. The fan on top was loose and not spinning. I fixed that, and it now spins properly, but he freezer and frig will not cool at all.
I need you to pull away from wall and remove cover over compressor and feel compressor for heat. If too hot to hold hand there or if warm or just cool. Tell me what you find. I would like to help you solve this if you like. Sea Breeze
Feb 21, 2010 | GE Monogram ZISS480NRSS 48" Built-In...
42" Built-in Monogram Refrigerator just lost power.
Check the Compressor starter. This is a black box on the top of the compressor. See if it is getting any power, also with a flash light you will be able to see if it is burnt it looks like a BIG fuse. If it is popped you will need to replace it then all will work ok after that
Jan 03, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
May 18, 2009 | GE Monogram Side by Side Refrigerator
How often are you supposed to change the filter? (GE Monogram)
GE recommends once a year for the water filter for light use and twice a year if used heavily.
Please take time to rate this fixya.
May 11, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
