Brake light stays on
Locate the brake switch up above the brake pedal. Push in on plunger and check if brake lights go out. This switch can be unplugged and removed from its spot at the pedal. Then you can pull out plunger and reset it, put back in its spot, and let pedal readjust to the appropriate travel. It should automatically set to correct stroke length after pulling plunger outward to its furthest length. If this switch, or its adjustment is not to blame, post again. I will help more if needed.
Thanks, I hope this helps. TT
