Question about Seagate Freeagent Goflex 500 GB USB 2.0 Ultra-portable External Kit and USB 3.0 Adapter S... Hard Drive
I got aComputer Tower and I want to install a Seagate free Agent Go Flex 500mUSB 2.0 how do I get a Instruction?
I have a PC.Tower with Microsoft Windows 7 in .But the Quick Start Guide it shows only a Laptop pickture .I try for HR.on the Internet to find a solution ,if I can Install this tipe of Drive ,or must i returne it to the Store ?Help please.thnks.Ps.I do not have a ''USB3.0" I have aUSB 2.0Hard drive
  • Seagate Master
  • 5,259 Answers
The connection will be the same (desktop or laptop, USB 2.0/3.0). Find an free USB Type A port on your computer. Connect the appropriate end of the USB cable to the Seagate hard drive and the other end to the computer's USB port. If you do not have any free USB ports, then you will need to get a USB hub or add a USB card to the desktop. You may need a powered USB 2.0 hub to ensure that the external drive works properly. (Warning: not all hubs are sold with the power adapter. Hard drives that loose power are often at risk of losing data.)
I hope this helps.
Posted on Jan 03, 2018
SOURCE: Seagate Free Agent Desktop Drive Not Recognized
I took my enclosure apart completely (not recommended since it was difficult breaking the snapping points), and I hooked up the drive just like an internal HDD. The BIOS was able to detect the drive so nothing is wrong with the drive itself.
I've also read that the controller on some of the FreeAgent drives fail. Mine started making buzzing sounds and finally failed. So you can take the drive out and put it in your computer, get a new enclosure, or send it back to Seagate where they should replace it.
Posted on Sep 14, 2008
SOURCE: help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
Posted on Nov 03, 2008
Alcatrazx
  • 65 Answers
SOURCE: Seagate Free Agent Drive Cannot be Modified on Mac G5
First of all Hello John :)
The new seagate drive you got needs to be unpartitioned and its file format system needs to be deleted and changed.
NB: You will lose all your data so make sure that you copy everything useful off it before you do these steps.
1. Get hold of a windows PC and right click on my computer
2. Choose manage ... choose disk management right click on the drive and delete the partition type
3. delete again until it comes unpartitioned space
4. Then go to your mac and you should be able to format it as a regular Mac drive.
5. If the Windows PC is inaccessible. Get hold of a copy of Linux UBUNTU distro. Boot your MAC from CD choose to boot os from CD (don't worry it will install nothring on your MAC it will just use the CD but make sure you choose the right option)
6. Keep your hard drive attached so it gets detected during bootup. Once the UBUNTU OS boots choose GParted and from there do the same thing i explained above.
Hope that this was of help :)
Cheers
(please take some time to rate solution)
Posted on Jan 07, 2009
SOURCE: problem removing write protect from seagate free agent drive
The problem is because Mac cannot write to NTFS formatted drives. You will have to reformat the drive in Mac. You will loose all the data :( Here is a link for the how to:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=174395
Posted on Mar 03, 2009
SOURCE: Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Posted on Mar 17, 2009
I need Seagate service center in Metro Manila. My 2 TB Free agent go flex external hardrive use to be working well. Recently the lights went off and can not be detected now.
Take the drive out he caddy and plug it into another computer to see if it still works. If the drive is dead then you need another drive.
Jul 26, 2016 | Seagate Computers & Internet
I backed up my files on my seagate 2TB free agent go flex home before my computer when down and now I got my computer replaced so how do I restore all my files into the new computer?
seagate has a utility for that which should be on the disk that came with it if not you can find it at www.seagate.com under drivers and/or applications by model number
pretty nifty app too
let me know what you find out
May 18, 2012 | Seagate 2TB FreeAgent GoFlex Home
How do i transfer data from go flex free agent seagate hard drive back to my dell computer. I need simply instructions please. Had to send my dell back with hardware problem and copy all data onto seagate...
Hello Paul,
Please visit the link provided below :
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=216951&NewLang=en
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=214103&NewLang=en
Aug 17, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
Transplanting Hard drive from Seagate Free Agent go flex to another enclosure. I believe the power supply is dead only one light comes on and it just beeps
Here's one case. They're not terribly scarce, but not found just everywhere, either.
http://www.amazon.com/Aluminum-External-Drive-Enclosure-Silver/dp/B000F3WB0Y
Jul 07, 2011 | Seagate Free Agent Go Small 12 GB USB...
Restoring backup from vista to windows 7 from
You have to install Seagate software for that then you can restore your data back to windows 7.
Jan 25, 2010 | Microsoft Windows Vista Home Premium for...
Seagate Free Agent Pro Out Of Space
format backup drive and repartition to a single partition. do not backup programs unless you have clone disk.
Jun 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Delete data from drive K on Seagate Free Agent PRO
Hi there! In order to solve your problem, just go to System Restore and restore your computer the date during you installed the Free Agent Pro, then try to re-install the application after the system restoration.
Nov 03, 2007 | Computers & Internet
Seagate Freeagent Goflex 500 GB USB 2.0 Ultra-portable External Kit and USB 3.0 Adapter S... Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
