USB data transfer from old to new computer
I have an old Gateway 700Mhz Windows 98 computer that I'm trying to connect directly to a HP Pavilion laptop with a usb cable. What is the procedure for this? Thanks.
    Problem Solver:
  • 12 Answers
You cannot directly link a Windows 98 computer to another computer via USB(without special hardware). The easiest way to do what you are trying to accomplish would be to hook both computers up to a router and share files over a network.
http://www.windowsnetworking.com/articles_tutorials/wxpwin9x.html
Posted on Jan 29, 2009
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
My computer will not power on, only a flashing green light on the back is on. I just bought a new computer and would like to transfer my files to my new computer. Why my old computer will not power on?...
Hi and welcome cj4man1 !
Extract the Hdd out of your old computer . Place it in a external usb box and connect the box to your new pc . You will be able to access and transfer your data .
The issue about your old computer is another matter an could have several reasons , such as power supply , damaged Hdd , defective memory , damaged motherboard ...etc ...
best regards ,
fanaudi .
Feb 20, 2011 | HP Pavilion a450n PC Desktop
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
I am trying to save data from an old computer that uses Windows 98 to a data stick through a USB por but am told it does not have a device driver
well...the new flash drives or usb drives are not compatible with windows 98 nemore buddy..
i wuld suggest either try to search for the device drivers on interent, which wuld be hard to find for sure
OR
take this hard disk, connect this with some other computer with another operating system, copy all data easily then.
Nov 01, 2009 | Microsoft Windows 98 for PC
Will a wireless ethernet adapter (USB WIRELESS 54 G NETWORK ETHERNET ADAPTER 54G G WiFi) work with my wireless Linksys 2.4 Ghz router? And also it will be connected to an old Gateway 700mhz Windows 98se...
The OS would be the only problem. You would have to make sure the computer had USB 2.0 ports and that the OEM of the network adapter has a driver for Windows 98.
Without the driver it won't work at all, without the USB 2.0 ports it might work but it won't perform nearly as well as it could.
Sep 26, 2009 | Computers & Internet
Transferring data from old computer to new computer
If its connected to the internet email the files to yourself and then save to your new computer. If its not online, you could try taking out the hard drive, make it a slave in your new computer and moving the data from one drive to the other then take it out and good to go.
Jul 16, 2009 | Computers & Internet
I answered you in another post, you need to network the computers via ethernet, not USB.
Jan 29, 2009 | Micro Innovations MCNCPQ5PHC USB PCI Card...
I've purchased a belkin usb 2.0 file transfer cable for transferring old files from a pc with windows 98 to a new laptop with vista, the transfer cable is not picking up the two computers on the old screen...
Hi
Im not sure you can transfer over a USB cable with different OS and filesystems. easiast way is to buy a usb harddrive or usbstick copy data to that. or if the old computer have a networkcard to transfer over a crossover cable or true a network Hub/switch..
Aug 13, 2008 | Belkin Computers & Internet
External hard drive
ya yiu can do it only you need is to download the drivers from the homesite of teh type of hard drive u r using
u hav not mentioned the name her so just simply try by searching google for the driver
Jul 28, 2008 | SimpleTech SimpleDrive 160 GB External USB...
C-150 OLYMPUS DIGITAL CAMERA
By connecting the camera to a computer with the provided USB cable,
images on a card can be transferred to the computer. Some OS's (operating
systems) may need a special setup when connecting to the camera for the
first time. Follow the chart below. For details on the procedures in the chart,
refer to the “Reference Manual” on the CD-ROM and the “Software
Installation Guide” (included in the CD-ROM package).
Identifying the OS
Windows 98/98 SE
(Second Edition)
Windows 2000
Professional/Me/XP
Mac OS 9.0 - 9.1/OS X
*OS 8.6: See below.
Connecting the camera to a computer using the provided USB cable
Installing the USB
Confirming the computer recognizes the camera
Downloading image files
Disconnecting the USB cable
Even if your computer has a USB connector, data transfer may not function correctly if
you are using one of the operating systems listed below or if you have an add-on USB
connector (extension card, etc.).
● Windows 95/NT 4.0
● Windows 98/98 SE upgrade from Windows 95
● Mac OS 8.6 or lower (except Mac OS 8.6 equipped with USB MASS Storage support
1.3.5 installed at the factory)
● Data transfer is not guaranteed on a home-built PC system or PCs with no factory
installed OS.
You can view images using: graphics applications that support the JPEG
file format (Paint Shop Pro, Photoshop, etc.); Internet browsers (Netscape
Communicator, Microsoft Internet Explorer, etc.); CAMEDIA Master
software; or other software. For details on using commercial graphics
applications, refer to their instruction manuals.
Jan 31, 2008 | Olympus Camedia C-150 Digital Camera
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
