Question about Dryers
Dryer heats for 10 minutes and turns off
Hi I have a kenmore front load dryer that heats for 10 minutes and then goes cold. We checked the glow plug and it does glow for the second round of heat but, never heats again. We checked the vent and all the hoses for lint. It still does not work.
Our is a 417 series
  • 4 more comments
  • bgld Jan 31, 2009
    Hi, Thank you for offering to help.
    I have checked the vent hose, no clogs. I have a very good air flow outside. I also took the front panel off and vaccumed the inside. (there was lint on the inside) I did notice that during the first "cycle" that heats my dryer gets very hot on the side and the front. I dont know if it ever did this before. Any help would be great!
  • bgld Jan 31, 2009
    Well I took off the drum and there was a lot of lent
    in the intake, I pulled it out and it came out as one piece
    in the forum of the intake and the edge was burnt.
    I put it all back together and again it
    will only flame up on the the start up but
    when the glow light come on about 10 min. later
    it does not light, the glow light keeps coming on but
    it does not light up again.
    i seem to have really good air flow out of the vent.
    and on start up when it does flame up
    the side closes to the flame and the back of the
    dryer becomes so hot that you can not touch it for long.
    thanks for all the help.
    the Model # is 417.9104200
  • bgld Feb 01, 2009
    Thanks,
    I have watched the flame and it seems to stay put,
    I'm thinking it might be the thermostat,
    I should have started this blog with more info.
    a week ago my water pipes under my house
    froze up and I used my dryer vent under
    the house to try and heat up my water
    line(will never do that again )
    but that's went this all stated,
    do you think that this might have caused
    it to overheat and maybe messed up the
    thermostat? again thank you
    I really do Appreciate it
  • bgld Feb 01, 2009
    I dont have or know how to use a multimeter(darn it)
    I'm not even sure where the thermostat is.
    it does not matter what temperature setting it is on,
    it gets very hot on the side and back.
    Thank you again.
  • bgld Feb 03, 2009
    I bought the part today and installed it, then I used
    a temp. probe in the vent next to the thermostat-control
    and ran the dryer empty, it got up to
    160 dreg. then shut off , it drop to about 120 dreg.
    came back on to about 160 dreg. it did this one more time
    so i thought that it worked however when i put wet clothes
    in it and turn it on it went to 160 and then drop but did not kick back on. this is driving me nuts.
    thanks again for the help
  • bgld Feb 07, 2009
    well I didn't replace the thermostat, because I had a friend
    check it with a VOM and he said it was still good.
    i can't really afford to replace parts unless I know that is whats wrong with it.
    I did disconnect the vent to make sure it was not
    clogged and it still does the same thing.
    it fire up and heat just fine at the beginning but when it
    should heat up again, the glow light comes on but
    no gas.
    thanks for your input and help
    President:
  • 1,214 Answers
Turn the dryer on, go out to the where the vent exits the house. Feel the air coming out, and it should blow very strong, and for the total diameter of the discharge. If it doesn't, the vent pipe is plugged, or the connection hose from wall to dryer is crimped/collapsed when pushed back to the wall.
Also make sure lint filter is clean, and the grill inside the dryer where hot air enters is clear.
Reply back your findings and I can help you more.
Posted on Jan 29, 2009
  • 4 more comments
  • Mark Egan Jan 31, 2009
    I'll need the full model number to help you more as I need to try and find the wiring diagram.But I'm real suspect that it may be shutting down on the overtemp stat, and that the inlet to the dryer drum may be clogged.
    Look up inside the dryer and you'll see two grills where the hot air comes into and leaves the drum. Are both of those clear? If not, clear them. One will be clogged from inside the drum, the other will be clogged from the backside, so you will need to access the backside unless you can clean it good from the front, without dropping chunks of lint back down and not retrieving them (not retrieving them, they will just blow right back up there.).
    Let me know what you find out.
  • Mark Egan Feb 01, 2009
    Well, your on the right path.
    The sides getting hot are an indication that the flame is either not going to where it is supposed to, or the thermostat is bad.
    The flame isn't going where it's supposed to because either the flame duct has a hole in it, or something has a hole in it or is missing, preventing the blower from drawing the flame into the flame duct toward the blower for some reason. On the alternative, if the blower cannot push enough air out of the dryer, it can't **** enough air to maintain control of the burner.
    Once the system operates like this for a few minutes, and heats up the mass of the dryer where it's not supposed to, the over temp sensor kicks out, and blocks the gas valve from opening (even though the thermostat says it needs heat.). And with all the heat in the mass, it takes a long, long time to cool back down enough to allow the overtemp sensor to reset.
    If you can watch the ignitor light up, then do this. Let the dryer cool down, and intiate a dry cycle, and watch the flame the whole time until it shuts off. Keep you face and hands/arms clear of any stary flames that may be about in the dryer, and be prepared to shut things off when the flame lights, in the event there is severe flame rollout (You don't want any singed eyebrows here. Been there, done that. It's not fun on a Saturday night, and it will really mess with that part in your hair.).
    Let me know what you find. You've made good progress so far. We just have not found the culprit.
    Oh, and by the way, good flow at the outlet is relative. But let's say that it should feel like you've stuck you hand out the car window at 45-50 miles per hour. Nice and strong.
    It could be thermostat, but then it may not be.The dryer doesn't know where it's venting to, under the house, or into the vent.
    Does the side of the dryer get extremely hot regardless of the dryer temperature setting?
    If you know how to use a multimeter, then somehow clip the meter across the terminals of the over temp stat, set to a scale something higher than 120 Volts, and turn the dryer on. You should not get a reading.
    If it trips out on overtemp, when the sensor opens, you will get a reading of 120 volts. And it will stay that way until it cools back down. If the problem is the temperature control thermostat, and the 120 VAC is always there, regardless, then it's the temp control thermostat.
    You access the thermostat from the back of the control head.
    1) Get a new stat.
    2) Unplug unit
    3) Remove stat knob from in front.
    4) Remove rear access panel.
    5) Disconnect wiring from stat, noting their connection points. You might try to connect to the new stat as you disconnect from the old stat.
    6) Remove old stat, probably a 1/4 turn and pull out, but there may be screws from the front holding it in as well.
    7) Install the new stat.
    8) Put everything back together and test.
    Let me know what you find. Stat is shown at $8.34 from Sears Parts website, P/N 134398600.
  • Mark Egan Feb 03, 2009
    Well, if all the vent duct is clear and the blower is not clogged up, and everything in terms of air flow is as good as you say, then go buy a new thermostat for the unit.
    What is driving me crazy is why the side and back panel are getting so hot. Warm makes sense, but hot doesn't, and tells me either the flame is not going where it's supposed to, or there is not sufficient air flow for some reason.
    I have to leave it to you to be the eye's and ears of what's going on. And I am here to give guidance, cause I know you can fix it.
  • Mark Egan Feb 08, 2009
    The problem is the high temp thermostat since you've bought and replace the thermostat, and you've seen it temperature cycle. The only thing left in the circuit is the high limit stat, and it's much cheaper than the thermostat that you said you've replaced.
    Note that the limit stat will read closed when it's cold, and the only way you can determine if it's the culprit is to put the voltmeter across it's terminals, set it to volts, and run the dryer.
    The meter should never read more than 0 volts during operation of the dryer, and if it does, then, you either have restricted airflow, or the limit thermostat is bad. One final check is to monitor the temperature like you did before, and watch the voltmeter. If the the limit stat opens at anytime (you read voltage), and the temperature is less than the 160 degrees peak you read before, then the limit stat is bad.
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
Dryer not heating. Originally worked for 10 minutes then stopped. Cleaned inside - spotless. Installed brand new ignitor (glow type) old one was fine - didn't need changed. Worked for 10 minutes...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 07, 2011 | Kenmore Dryers
The Kenmore dry glow plug lights but the gas only comes on initially. After a few min the gas goes out and the plug glows periodically but no flame
heatman101
Jun 27, 2011 | Kenmore Dryers
My front load Kenmore dryer runs but does not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 06, 2011 | Kitchen Ranges
Kenmore electric dryer keeps blowing cold air.I have replaced the thermal cut-out and it lasted for 1 load.The ducts are all clear and i dont know what else to check
heatman101
Dec 18, 2010 | Dryers
Dryer wont heat just spin
heatman101
Nov 29, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Turn dryer on runs about 1 minute gas goes off what could be the problem
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 06, 2010 | Kenmore Dryers
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
It appears your thermocouple or gas valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 31, 2009 | Kenmore 98702 Stacked Washer/Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
348 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
