My 2007 dodge magnum wont crank i was driving on the freeway saw that the oil light was on pulled over turned it of checked the oil was good drove it again light came back on and the it started to bug out causing me to lose power and then it shot off now wont turn over
Sounds like the engine is toast.
The warning light means the oil pressure has dropped below 10psi which can mean the engine is low on oil, or that something has happened to the oil pump or other components.
The crank bearings may be seized from lack of oil.
See if you can turn the crank by turning the alternator pulley.
SOURCE: 2007 dodge magnum 2.7 v6 made a noise when i
the bendix may have gone bad. take the starter off and take it to an auto parts store such as auto zone they can test it.
SOURCE: I HAVE A 2005 DODGE DURANGO CHECK ENGINE LIGHT IS ON
The code that tells why it died is the P0068 the throttle position sender. It can be bad but they usally last a long time. Other sensers can have troble and pull down the 5 volt reference signal and it'll make it appear that the senser is bad. You can pump the gas very quickly many times and make even a good car set this code. The computer sees a smooth signal from the senser it'll set things back to normal and it'll run just fine. The senser can be teated with an OHM meter center pin of the serser to one or the other outside termial. with the meter making a good conection. the senser should make a smottth change up and down and return to the same value as you started and never go off scale, the other terminal should do the same thing but only in the opasit direction. If it doesn't its bad but a new one stick in on fire it up and run down to the store and have them erease codes telling them you replaced the bad part and need to reset. Even then they sometimes won't do it as some stores have run into troblem with the wrong customer and they don't reset codes anymore. Then you'll have to go to a shop the has a code reader or a scanner to reset the light and or buy your own but about $80 is the cheapest you'll see for a reader that will reset (erease cdes) on OBDII vehicals. good luck
SOURCE: Location of Crank Sensor
Front of the engine near the the timing chain cover, this is a picture. Make sure the connector is clean and free of corrosion.
300? 300: true ); MAX-HEIGHT: 400px; ; HEIGHT: expression(this.height > 400? 400: true )" src="http://info.rockauto.com/getimage/getimage.php?imagekey=1005895&imageurl=http%3A//www.standardbrand.com/web_app/catalog/images/PC127.jpg" />
SOURCE: 1998 dodge neon turns over but wont start
your crank sensor it is located on the back of your engine block behind the alternator check it see if it is bad
SOURCE: 2000 dodge durango wont cranks but wont start...
had same problems with cranking and wouldnt start , i had no spark not sure if you do but if not after performing tune up and still had no luck , i changed my camshaft position sensor under distributor and rotor , and she started right up . good luck
