Question about Kitchen Ranges
I have an electric wall-mount double Whirlpool self cleaning accubake oven. Can't fnd my manual, so I don't have the model number. It is 9 years old. Put on self clean feature, and it shorted out, and door remains locked. My breaker switch is not tripped. This happened a couple of years a go and the repair man said this was not uncommon. I cannot recall how he got the door opened, nor what the exact problem was. I would prefer to diagnose this myself...can you help me open the door?
I have a wall mounted electric whirlpool self cleaning oven. the oven door was opened too far down and came off. Now I can't get the spring loaded hinges back into the body of the oven.
Posted on Jan 23, 2010
  • 1,214 Answers
If you can see through a grill just above the door, then you might can see the lock linkage, and get something to push the linkage over (be sure to disconnect power first.).
If you can't, you'll need to pull the unit out from the cabinet and access it from the top.
The problem is often a thermal fuse in the top of the oven. But if you can provide more detail info on the oven, I can investigate further.
Posted on Jan 29, 2009
Whirlpool self-cleaning feature not available
Because the features mention utilize 220 VAC power, I do not advise you attempt any corrections. Very dangerous; unless you are a trained technician. If the unit is in Warranty, get the Whirlpool folks out to you home ASAP.
Dec 19, 2013 | Whirlpool Gold GGE388LX Double Oven...
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Oven is 75 degrees off temperature setting. what do I do?
Are you sure that no one has been taking the control nob off of the dial and turning it as a prank?
Feb 08, 2012 | Whirlpool Accubake RF362LXTS Electric...
I can't find my owner's manual - how do I clean my Whirlpool Accubake Self Cleaning oven?
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Cleaning cycle stuck whirlpool rbd245pdb1
whirlpool self-cleaning electric built-in oven #RC8400XAB serial # XD1301008. Self-cleaning lever locked. How can I release it???????
Jun 10, 2008 | Ovens
Kitchen Ranges Logo
215 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
